Something different
/ Something different #1
DEON
NS Canada
Kioti CK25 HST w/home built cab
I have been modifying my CK25 loader.:eek: My purpose is to do 5 things. I wanted better visibility, more lift capacity, more curl strength, eliminate the sloppiness of the QA loader and end up with a self leveling bucket. Unfortunately I ran out of time so I did not complete the self leveling parts. The snow will soon be here so I put it together as is until spring.
I used the boom lift cylinders for the curl. As they are longer, I was able to space the curl pins farther apart to gain over 40% in curl strength.
I replaced 1.77" ID boom cylinders with 2" ID cylinders and spaced the boom pins farther apart to gain about 50% more break out force. I lost about 3" height at full lift but I seldom lift the bucket all the way to the top as most of my loader work is dirt and snow, no hay and no fork work. I also spent a good amount of time reinforcing the loader frame bass so as not to break the tractor transmission/engine assembly. I compared my front axle and pivot assembly with other tractors with much stronger loaders like the L 3940 Kubota and LA724 loader rated at 3403 lbs. breakout force. The CK25 is built almost identical if not stronger then the much larger L3940 with a longer loader that extend much farther forward so I felt comfortable with my added loader capacity.
Anyway, I did not take any photos while building but you can see the old loaders towers in the background in one of the photos. Have fun looking. I will post again when the self leveling is completed.:) Oh, I put it to the test today in an old pile of pit run and did a little driveway grading. I am amazed at the added strength, stability and precise control. Feels like an industrial tractor.
/ Something different #2
looking good
/ Something different #3
Sure looks good. As I am not all that familiar with the details of Kioti and loader, I would not know that you had changed anything without seeing a stock unit and then immediately looking at yours. Do you have a way of checking what the lift capacity is now? With the added lift capacity, be sure to keep a heavy counter weight on the 3PT. :cool:
Have about 1,000 lbs on the back with counter weight and cab.
Don't know the exact gain as I am only working with the calculations and experiencing the difference in feel. My calculations are somewhat close as the feel when operating is very obvious. I can stuff the bucket in a pill of pit run and just curl a little and lift. In that type of material I previously needed to fill the bucket by scraping up the side of the pile.
See the before and after photos.
/ Something different #5
Wow! That loader looks much more stout. Nice work!
/ Something different #6
I have a good friend that wisely reminds me when I want to reinforce my boxblade so I won't trear it up when I hit the water main cutoff valve housing, that the weakest link is what is going to break. Since the boxbade is the easiest part to fix, I haven't reinforced it, for fear of breaking a part on the tractor. (everybody knows how expensive Green paint stuff is!)
Just keep that in mind as you use your reinforced loader. Just because it will do it, doesn't mean you need to let it do it.
David from jax
/ Something different #7
From the before and after photos, looks like you rebuilt the whole loader frame and just used the bucket. Is that what you did? Looks good. I wouldnt know where to start to do that kind of work. After seeing your post, I thought I might rework my bucket attachement points to give me more breakout force like you did. By moving the attachment point higher on the bucket, that should add more leverage, right?
/ Something different #8
Have you measured or calculated the difference in cycle time. There is always a trade-off of power vs speed. I believe that by going from 1.75 to 2 inch cylinders you have increased cycle time by 25 percent and depending on the change in bucket pin distance the bucket will be slowed more.
Your work looks professional! Nice job.
Loren
/ Something different #9
That is amazing. You should be in the FEL making business, what a great job.
Very interesting idea, but way over my head for skill. Thanks for sharing and show us your next projects, I bet they'll be great too.
/ Something different #10
Very well done Deon. I definitly think that the mfg's intentionally do not engineer fel's to max capacity due to the "liability possibilities". If they could control how much counter weight was on the rear, then I bet they would beef up the loaders. I put Bush Hog bucket on my DK40 that has 40% more capacity than the standard Kioti bucket. The fel lifts it full of gravel with no prob, but even with loaded tires and a 7' box blade on the back it's still light in the rear. More counter weights are in my future;)
RD
I used all of the existing loader but cut it about half way and shaped the side plates that the cylinders are attached to to make it look like it is now.
You can add distance between you bucket pins to add strength but you will loose some of your curl travel. I replaced the curl cylinder with the boom cylinder to keep my curl travel complete.
Loren
Yes, I have slower cycle times but the KL130 was very fast. Much faster that most other loaders. I like the speed better now as it is less jerky and easier to do finer work. If I want to cut 1/2" off the top of my soil, the loader is now very solid and easy to set. Without the loose parts of the QA loader, plus the extra strength of the whole design, the bucket stays where its set. I need to take care of my float control because I will be needing it while pushing snow.
David from jax
Your friend is wise. That is why I designed the loader mount to spread the load all the way back to the rear axle. My loader will still break or bend before the tractor breaks.
/ Something different #14
I know you said that you would, but please do let us know how the self leveling part goes. The rest looks great, and thanks for posting the side by side pics, sure makes it easier to see what you have done. :cool:
/ Something different #15
Very professional looking work, Deon. Both on the loader and on the cab. You have an awesome setup there.
/ Something different #16
If the manufacturer designed the front axles to support a certain loader capacity, isn't there potentially excess stress being put on the axles with the new loader capabilities?
/ Something different #17
You can add distance between your bucket pins to add strength but you will loose some of your curl travel. I replaced the curl cylinder with the boom cylinder to keep my curl travel complete.
That's a good idea, going with longer stroke bkt cyls to restore your
curl angle. I did not do that when I increased my pin spacing from 5.5"
to 8.5" for my 4-in-1 and my fork frame.
As for cycle time, I agree these tractors have plenty of flow. Virtually
identical to the L3x40s at 8.3 GPM.
Looks great, DEON.
/ Something different #18
When QA is mentioned in this thread - we are talking Quick Attach as far as the loader frame goes, correct? The bucket doesn't look like a QA. I may be interested in adding the new bucket with QA to my CK30 as long as it is not loose or sloppy. The original poster says the QA had some play in it. I don't notice that, (or it doesn't bother me), as far as the frame goes. How about some new CK owners with the new QA bucket? Is it snug? Thanks
/ Something different #19
QA almost always refers to the bucket attachment at the front of the FEL, not the FEL frame at the tractor.
I don't know exactly what the others are reporting with regard to "loose or sloppy" but standard skidsteer QA adapters can certainly slide side to side with force. The retaining pins fit into slots, not round holes, so with sufficient lateral force they will slide a bit. Not usually an issue that affects safety or performance though and the slide is usually only a couple of inches. There cannot be any sliding if the top of the QA adapter fits snugly but often the FEL adapter is slightly narrower (or in the Kioti DK case about four or five inches narrower) than the bucket/implement mounted receiver plate....in that setting lateral force can cause "sloppy" movement occasionally.
/ Something different #20
Original poster says he wanted to eliminate sloppiness in the QA loader. I just wanted all to be clear that he is talking about the arms, not the bucket. I never heard of the arms or the loader itself refered to to as QA. Quick disconnect would be the appropriate term. The new bucket is bigger, heavier, etc, on the new CK30's as well as QA. This could be something I'm interested in so that my son can load more firewood in the bucket............
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
(10) Field Cultivator Shanks (A65640)
(10) Field...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
