Car Brake Rotor Replacement / Resurfacing
/ Car Brake Rotor Replacement / Resurfacing #1
Travelover
Elite Member
Washington
B7100
I used to do all my own car repair, then took 25+ years off when I had a new lease vehicle from work every year. Now I'm back to owning and maintaining my own vehicles, but a little behind the times. :eek:
My question is about brake rotors. If the rotor thickness and run out is within specification, does it need to be turned or replaced when new pads are installed?
Thanks.
/ Car Brake Rotor Replacement / Resurfacing #2
I think they are typically resurfaced with a grinder to make everything true again. They don't cost an arm and a leg to replace like they used to for the average car.
Dave.
/ Car Brake Rotor Replacement / Resurfacing #3
We used to "turn" brake drums and rotors, as you probably remember, on a machine that shaved a bit of metal off. In more recent times, if the rotors are not warped, we just use something like an angle die grinder to remove any glaze from them, sometimes without even removing the rotor from the vehicle. Sandpaper can be used, although they also make some pads specifically for the purpose.
/ Car Brake Rotor Replacement / Resurfacing #4
Like others have said you can have the rotors turned or replaced. But if they are not to bad you can just take a hand grinder and touch them up. If they got hot and warped they need to be replaced.
Most new rotors are only a few bucks more to replace than to get the olds ones turned. So usually recommend getting new ones if they are warped or grooved real bad.
/ Car Brake Rotor Replacement / Resurfacing #5
Changing rotors has become the norm. I just bought a pair of brake lathes from a mechanic that works for a dealership and at home evenings & weekends for private clients. At the dealership it was determined a while ago that they make the same or more money selling new rotors/drums than they could charge to have a mechanic turn them. With multiple mechanics you wouldn't want them waiting for their turn at the machine, less waiting at the parts room. The mechanic figures he can just order new and guarantee the clients car will be ready on time, he makes the same money, & puts in less time. The machine shop I've used in the past has upped their charge to turn a rotor to $25 to discourage customers from asking. I paid $250 for two lathes, one for rotors & one for drums, old but in good working condition. I've turned 8 rotors since September and am only two from breaking even. Since I do my own work on family vehicles I find it worthwhile to be able to take the vibration out of one rotor at my convenience & before it gets real bad. MikeD74T
/ Car Brake Rotor Replacement / Resurfacing #6
If they're within spec I'd just put new pads on and go. But it would'nt hurt a thing to do a little sandingt on them to knock the glaze off.
/ Car Brake Rotor Replacement / Resurfacing #7
The newer brake rotor machines turn the rotor while still on the vehicle. They seem to do a good job of making the surface true and match the rotor to the caliper.
/ Car Brake Rotor Replacement / Resurfacing #8
I'm easy on brakes and use Factory Pads...
I inspect for problems and if the brakes are working fine... only the pad is near the end of useful life, I hang new pads...
Some will say you can't do it...
I've done it on a whole line of Chevrolet Cars and Trucks... Toyota and BMW... never had a problem so far.
/ Car Brake Rotor Replacement / Resurfacing #9
Our local NAPA store turns them for $5 each, for my Toyota Sequoia they want $130 per 'premium' rotor :eek: Guess which way I went ;)
This is what I always did, too, back when I was servicing my own cars. I'd check the thickness and run out of the rotor or drum and only turn if needed. I guess I can see where the pads might not break in as fast on a glazed surface.
/ Car Brake Rotor Replacement / Resurfacing #11
A key point; "premium rotor". Sometime I think cutting old good rotors is better than buying new crap that is in the stores today. Brake pads, same thing. I seem to have better luck with the better quality.
I am getting tired of the cheap junk sold. Just replaced a ballast in a fluorescent fixture. Only about year or two old. Seems every new fixture I buy burns the ballast after a couple years. Geeze, I have some fluorescent fixtures in a building that has scads of lights at least 20 years old. I can remember two out of 30 failing in 10 years. So, in the long run, do we save anything by buying the cheap junk?? It might even cost us more in the end?? In this case , replacing ballast cost me a trip to big box, 15 miles round to box, an hour walking around buying more junk I don't need and back at shop and hour to replace. And...don't forget... the cheap stuff takes North American jobs that turned out quality goods.
Just thoughts from the Coffeeman.
/ Car Brake Rotor Replacement / Resurfacing #12
Very true on some of the Energy Saving fixtures we see being sold today... when you add the cost of a short life span plus the labor if you can't do it yourself...
I change 2 ballasts a week here... so far none of the replacements have gone bad... I buy them through Grainger.
/ Car Brake Rotor Replacement / Resurfacing #13
I'm with a couple of the others, I just replace the pads and go. Got 205,000km on my last set of rotors on the Dodge pickup. The rotors were really toasted by then though.
I also use softer pads as someone told me once it makes more sense to wear out the pads than ruin the rotors. I have no idea if that is true but it's worked so far.
Note: The rotors were HORRIBLE to remove after all that mileage. It was very very hard to remove them.
/ Car Brake Rotor Replacement / Resurfacing #14
I'm about to put my 3rd set of rotors on my dodge truck. this truck eats brakes, and before I realize it, the rotors are toast.
And when I went to move the truck the other day, no brakes. Got a leak in the back line.
Oh, and the shop light ballasts are all junk.
/ Car Brake Rotor Replacement / Resurfacing #15
I just got a recall notice in the mail yesterday for my 1995 F250 saying to come in and get a new speed control deactivation switch installed for free.
/ Car Brake Rotor Replacement / Resurfacing #16
Get the rotor thickness checked before installing new pads. So long as
they are not warped (vehicle shakes) or glazed over put on new pads and go.
If they are warped, replace... They will warp again...
If they are glazed and above tolerence a light turn is in order.
If they are below tolerence, replace...
An eyeball is not a sufficent measuring device. There is a fine for turning
out of tolerence rotors so don't ask! (pet peeve sorry)
In the last twenty years or so the amount of extra metal or tolerence
has been lessened greatly so some rotors get only one turn or maybe none
at all. Composite rotors are difficult to turn and best replaced with full cast
versions.
If one side is worn more than the other side, you have a caliper issue.
Out board side is the caliper pins on a sliding caliper, inboard is a stuck
piston or collapsed hose generally.
Major difference on regular replacement rotor vs. premium rotor is the
premium is made in USA.
HTH...
/ Car Brake Rotor Replacement / Resurfacing #17
Do NOT take a hand grinder to a brake disk. :eek:
You'll do more harm than good.
/ Car Brake Rotor Replacement / Resurfacing #18
A weekend racer at work had the same trouble with his Jeep Grand Cherokee going through rotors...
He had a pair treated be some super-freeze process like they do on race cars and the problem went away...
/ Car Brake Rotor Replacement / Resurfacing #19
No more than rotors cost for the two vehicles in our 'fleet', I replace them when the pads are shot. I don't get surprised by needing more parts when the vehicle is up on jack stands, and I don't have to worry about whether the pedal will pulse due to a warped rotor. If my replacement rotors cost a lot more (as some do), I might think differently.
/ Car Brake Rotor Replacement / Resurfacing #20
This is a quick fix- but one you should get done esp. if you park the truck in a garage. It took 10 minutes including paperwork for my 1995 F250. The truck can burn to the ground even when parked and off. The brake fluid can leak at the switch and for some reason the switch is still live even with the ignition off. I actually unhooked mine before I got the fix done- couldn't use the cruise, but I don't use it anyway.
2018 Towmaster TC-16 10 Ton Tag A Long Trailer (A61568)
2018 Towmaster...
UNUSED WOLVERINE MCB-11-48W 48" HYD MINI 4N1 BKT (A62131)
UNUSED WOLVERINE...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
HAMM 2420D SMOOTH DRUM COMPACTOR (A62129)
HAMM 2420D SMOOTH...
Gehl RS5-19 (A62177)
