Members home made attachments / improvements
   / Members home made attachments / improvements #191
:confused: Hey!!...Where are all the creative minds out there???? I just noticed the number of hits this thread has had. It's bouncing back & forth with MR's backhoe thread. 30,ooo...plus views but not too many pictures of PT custom attachments, Mods, or Improviments...Whats up with that?? :p :D
   / Members home made attachments / improvements #192
Has anyone come up with a good solution for the crappy, plastic, non castered rear mower wheels?? My brush mower with the Caroni caster wheel kit worked great...after I installed a smaller, solid rubber caster tire. :D
   / Members home made attachments / improvements #193
Rivco said:
after I installed a smaller, solid rubber caster. :D
what was wrong with the pneumatic tires that you installed initially?
   / Members home made attachments / improvements #194
I had a clearance problem.:eek: The larger pneumatic tires would sometimes hit and rub the PT front tires. When I installed the Caroni kit I had to move the mower attachment plate bracket back 5" to extend the mower further from the PT for clearance.
   / Members home made attachments / improvements #195
Hey I'm bumping this to the top again. It's been a long time since anyone has posted pictures of any custom PT attachments or improvements. Winter is coming and I love to see the creativity flowing :)
   / Members home made attachments / improvements #196
In relation to the title of this post I am working on making a useful tool out of this for my PT 422. Somewhat of a challenge but I gave a song for it and have use for its lifting height. 14 ft and 4000 lbs at the forks. Granted I wont lift the full weight but I want the height for a man lift.
   / Members home made attachments / improvements #197
Interesting with great potential. I'd be a bit concerned about counterbalance though, especially with a PT. How do you PT guys deal with adding ballast given the lack of 3pt attachments and small wheels (not worth loading I'd guess)?
   / Members home made attachments / improvements #198
The safe lifting capacity on the Power-Trac's is figured from the side loads on the wheel motors, the size of the cylinders, the angle they are mounted, and the distance the load is from the pivot point. Any more weight than that is called the pucker factor.
Although we could add extra weight to the rear, and therefore lift a greater weight than advertised, it is not advisable as the hydraulic wheel motors were not designed to work with greater loads. Shaft seals will start to leak, etc.
   / Members home made attachments / improvements #199
What was the original purpose of the yellow attachment. I am guessing , a 3ph attachment to lift hay bales or rolls. How much weight do you think it will lift.
Did you put a QA on it ?
I re-read and saw the 4000 lbs. Do you think those wheels will handle 4000 lbs?
   / Members home made attachments / improvements #200
That's a great idea !!. Some of you might remember... I built a hydraulic boom lift that had a lift HT. of 12'. I added caster wheels to the frame...very similar to your picture. You have built some great custom attachments in the past so I'm looking forward to seeing pictures of the completed man lift.
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
Portable Restroom (A54865)
Portable Restroom...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
