3000 Charge Pump??
/ 3000 Charge Pump?? #1
evan4434
Iowa
Cub Cadet 3184
Does anyone have an instructions on replacing a 3000 charge pump? Do I just unbolt it and bolt the new one on? I also read something about purging the hydraulics, how is this done?
My 3184 has been making some strange noise since I got it from the hydraulics. It is so bad sometimes I can feel in in the steering wheel. I have narrowed the noise down to either the charge pump or the part the drive shaft bolts too on the transmission. Anyone every heard of this? I have replaced the fluid and filter, and that did not help at all.
/ 3000 Charge Pump?? #2
I recently replaced the charge pump on my 3186. It just unbolted and the new one went right in place. I started it back up and didnt need to purge the lines. The whole process took about an hour. Some people have done it through the sea opening but I took the fender assembly off to see and clean everything better.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2015 BOBCAT T590 SKID STEER (A62129)
2015 BOBCAT T590...
YANMAR VIO17-A EXCAVATOR (A62129)
YANMAR VIO17-A...
KUBOTA M135X TRACTOR (A62130)
KUBOTA M135X...
(2) 460/85R38 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R38...
2018 Freightliner M2 106 Single Axle Dump Truck, VIN # 1FVACXFC4JHJM9637 (A61165)
2018 Freightliner...
