well pump pogo stick??
/ well pump pogo stick?? #1
rhinert
Hi All,
I've got a problem with a well pump.
In this setup, the Sta-rite motor/pump assembly is mounted on to the top of the well casing about a foot above ground level. When power is applied, the motor/pump assembly jumps up about an inch, a lot of water will squirt out around the top well seal and then the motor/pump assembly falls back down. Then the cycle repeats at a rate of about two jumps a second.
The well was professionally pulled and rebuilt about two years ago when it had this same problem. Any ideas what's going on and how to permanently fix it?
/ well pump pogo stick?? #2
Welcom
got any model numbers or pictures?
search on how to post if you need to
I don't understand what is leaking it is it a pitless adapter? were pump hooks to horizontal pipe.
is it plumed with polythene pipe or rigid?
products
tom
/ well pump pogo stick?? #3
check that the air bladder is charged correctly, some where around 30 psi air pressure I think.
make sure that is working which can cause the pump to cycle on/off fast.
mark
/ well pump pogo stick?? #4
Is it a deep well jet pump? shallow well jet pump? Is there a pressure tank? Pitless adaptor? Foot valve?
If it is a deep well with two pipes and the injector in the well it might be plugged at the injector -- need a little more info
/ well pump pogo stick?? #5
based on the question id have to guess the OP has provided all the info they know. ;)
/ well pump pogo stick?? #6
Hard to diagnose with that information but you seem to have two problems at least. Something is not fastened down. There is no way a pump should be able to move up and down. The repeated jumping appears to be a "short-cycling" pump - not enough air in the pressure tank. Should be 2 psi below the cut-in pressure.
Why the pump jumps up and down is a complete puzzle.
Harry K
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2021 Tesla Model Y Long Range AWD (A61574)
2021 Tesla Model Y...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
23ft. Zodiac...
More info coming soon (A61569)
More info coming...
