FEL (Front mount vs. Mid Mount) ???
/ FEL (Front mount vs. Mid Mount) ??? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I was told that a FEL that had Mid Mount attachment system was considerably "Better" than one that utilized a Front Mount system. What is your opinion? Why would one be better than the other. thanks
/ FEL (Front mount vs. Mid Mount) ??? #2
stability, and not so much force on front parts
/ FEL (Front mount vs. Mid Mount) ??? #3
Here's the way the ML250 FEL is attached to my Mahindra 5525.
Seems to me that it's the logical way to support a loader capable of lifting nearly 3000 lb to 10.5 ft height.
/ FEL (Front mount vs. Mid Mount) ??? #4
Almost any respected loader manufacturer makes good mounts. Some tractors aren't strong enough for a front mount. Both styles load the front end the same. It just affects how much load is on the block and tranny.
/ FEL (Front mount vs. Mid Mount) ??? #5
Any examples (pics) of a front mount FEL? Brand names? Not sure I've ever seen/heard of one. ??
/ FEL (Front mount vs. Mid Mount) ??? #6
The loaders look the same, its the mounting kit. The types I know of:
1) Bolts to front axle pivot casting and to the engine block.
2) Bolts to the engine block only
3) Bolts to the engine block and arms go back to under the rear axle.
4) Bolts in all three places.
You have to get up a close to see how it mounts. A light loader may use one system while the same companies heavier loader uses more attachment points.
Those with extensive front and rear braces are a pain in the @$$ to work on. Filters, starters, clutch replacements etc all a real pain. They are strong though.
/ FEL (Front mount vs. Mid Mount) ??? #7
Anyone ever put a new loader on an older tractor and come to find that the things is slower than mollasses? How about experience a loader that you can't see over when you drive? The whole purpose of mounting brackets is to merge a loader with a tractor. How well of a job the loader company does, affects how "comfortable" the two units feel when they work together. Positioning too high results in severe tunnel vision, positioning too low requires axle stops or tires to be set out. Positioning to far forward results in a light rear end and low lift capacities. So it is good to see and review how mounts are designed when you are considering a loader.
FRONT-PUSH
The front-push style mounts are typically for 2WD tractors, they attach to your tractor in a way to keep the strain and stress off the smaller front axle. It allows for precision positioning of the loader on the tractor. See 2wd vs. 4WD - poor fit sits too far forward. Our 2WD loader line is based off the "horsecollar" principle from years ago - which distributes the weight through the entire frame to minimize wear/strain. The design of the mounts allows us to make a faster operating loader with smaller cylinders that is as strong as a 4WD loader. Ideal for older models with slower hydraulic systems.
TWO-POINT MOUNT
All of our loaders utilize a 2 point mounting system on a tractor, except our new freedom mount loader. What we have found is the mid-mount style forces "all" the sideways AND up & down pressures into just one small location on the tractor. The mounts "have" to be heavy and stout and attached with very high grade hardware. They should be checked regularly for proper torque.
The two point mount concept allows us to seure the loader (up & down force) on the tractor in one location (usually midsection) and move forward the attachment point for the side to side force (usually above front axle). This helps minimize the weight of the brackets allowing loader to lift more with less strain and it typically makes the brackets less expensive and more universal to other tractors. This increases the long term value of your loader not just on your tractor but many others in the same HP range. It promotes a "floating" type of connection between the tractor and loader where the are tolerances allow the forces of digging to dissipate through the loader/bracket connection points before being entirely absorbed by the tractor.
The best benefit of the two point mount is that it allows our loaders to automatically guide themselves on or off the tractor without having to mess with lining up pins or using tools. This is user-friendly and allows the loader to lock on automatically after you drive into it.
MID-MOUNT
This style is really tailor made for your tractor - it allows super easy installation - just bolt on two brackets and your done. This could be why you hear them recommended by dealers. The mid-mount or freedom-mount brackets offer more room for tire clearance and fenders and promote a "tight" connection to the tractor. Today's casted framed tractors where the tires oscillate and turn into the body just don't leave room to bolt on brackets. The auto locking features of this style bracket are typically more complex.
I've upload a few different style bracket photos.
/ FEL (Front mount vs. Mid Mount) ??? #8
Westendorf-RR:
Thanks for the info on the FEL attachments.
That ML-250 FEL on my Mahindra 5525 is made by Buhler/B.I.I. Fargo. I like that design--lotsa thick steel in the FEL support structure and the FEL loads are distributed to four locations on the main tractor structure. So far I haven't been able to bust it.
/ FEL (Front mount vs. Mid Mount) ??? #9
I grew up in the Fargo area and am very familar with Buhler - they make a good product.
Yard Machine Riding Mower (A61166)
Yard Machine...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
LandHonor LHR-G209 Anchor Shackle Set (A60352)
LandHonor LHR-G209...
2019 GENIE S-40XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-40XC...
Aerohot Commercial Waterless Food Warmer with Sectional Infinite Switch Controls (A60352)
Aerohot Commercial...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
