GMC dual battery option
/ GMC dual battery option #1
downslope
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I have a 2008 Chevy 3500 with the factory dual battery option.
Can I remove one of the batteries to use for something else?
I really don't require dual bats in the truck.
Anything I have to watch out for, which one to remove, what to do with cables, etc??
/ GMC dual battery option #2
I removed 1 battery for a summer to use im a tractor with no problems from a 99 ford power stroke.
/ GMC dual battery option #3
couple questions
What type engine?
Was the dual battery for towing or a plow / winch package?
do you tow?
tom
/ GMC dual battery option #4
If you have the Duramax than I definitely wouldn't. But you say you have the "option" on your truck which I would figure based on that that you have a gas engine. If that's the case than you should be fine, depending on your use of the truck as mentioned above.
/ GMC dual battery option #5
Sorry to be blunt but why mess with your $35,000 trucks electrical system over a $50 battery????? Kind of like walking over a dollar to pick up a penny. Not being rude, I am as cheap and frugal as they come, but some things I have learned just do not pay and will cost you more in the long run.
Chris
couple questions
What type engine?
do you tow?
tom
The truck is a gas 6 liter. The dual battery was a separate option. The truck also has a plow package option. As of now I don't have a plow for it and do not tow.
I just figured that since I don't need the two batteries it's a waste to leave both in place and what do I do when one goes bad, replace both of them?
I could find use for the 2nd battery in a Corvette that I drive ocasionally.
/ GMC dual battery option #7
I see no problem as they are wired in parralel, but do a real good job of covering that positive terminal. I do agree with DP though, I don't know that it is worth it.
/ GMC dual battery option #8
I believe the second battery is to help with cold weather starting. You will probably get shorter battery life and some extra strain on the starter which might shorten its life.
Baby Goat Decorative Statue (A66738)
Baby Goat...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2018 DODGE CHARGER (A66091)
2018 DODGE CHARGER...
2017 Ford Transit 250 Cargo Van (A66736)
2017 Ford Transit...
2010 Kia Soul SUV (A66738)
2010 Kia Soul SUV...
