Rake Landscape rake question
/ Landscape rake question #1
iplumb
Gold Member
Mason MI.
B2920
Never used a landscape rake. Can the top link be adjusted to make them less aggressive? Would it be possible to use on a lawn for leaves? Thanks
/ Landscape rake question #2
Do you have unground Irrigation? If so you'd tear out the sprinkler heads.Yes, you can adjust the pitch of the rake with the top link but I think you'd still tear up your lawn. Maybe gauge wheels would help if you had them on the rake. I'm in the process of shopping for a lawn sweeper. Agrifab has a 42" for about $300 here. There are several other brands to look at such as Brinly. I'm gonna get a lawn sweeper before this up comping summer. bjr
/ Landscape rake question #4
I think you could rake leaves with a rake......Carefully, so long as the lawn is largely flat.
With gauge wheels it would be less stressful.
Try it in an area that isn't of great importance and decide for yourself.
/ Landscape rake question #5
Mine is not very effective on leaves. My experience is that you begin to pick some up but as they gather they begin to roll out from under the tines. I made a "ladder rack" out of angle iron that holds 4 cinder blocks and is bolted to the top of the tine frame. It helps immensely but it is hard on the lawn. Without added weight or down pressure you need a sweeping action or multiple rows of tines to really be effective.
That said, my rake is one of my most used implements. Particularly with the added weight of 2-4 cinder blocks, it is excellent for grooming gravel roads/driveways, dirt and when angled even does a remarkable job of plowing snow.....I know, doesn't sound like it would work because of the spaced tines but it will collect and windrow snow (or packed gravel or dirt) like no ones business.
Snow:eek: Really!
/ Landscape rake question #7
I use mine on leaves and limbs all the time. It will scrape a little grass at first, but once there is some debris in the rake the scraping is very minimal. The little bit of scraping that does occur doesn't bother me at all, I never plan on achieving yard of the month anyway.:rolleyes:
Sounds like we are on the same page....Thanks
/ Landscape rake question #9
I bought a used light duty landscape rake this summer for that exact reason. I gather lots grass clippings and even more leaves for composting. I have not done my leave collecting this year yet but it worked great on the grass clippings. I blow it into a windrows with the mower, drop the mowing deck and put the rake on and just pull the windrows into piles. It is not perfect but sure beats raking two acres by hand. I have done that for a few years. It worked MUCH better then I expected. When I used it in my yard I shortened the top link to make it less aggressive, but it still scraped up dirt in the high spots, but I'm not bothered by that at all. I badly need the compost for my garden soil and never cared for the golf course look.
It did a remarkable job on my driveway as well.
/ Landscape rake question #10
Snow:eek: Really!
Really. On an angle it will pick up small or loose material and deposit it in a windrow at the end of the rake. It makes more sense if you think about it, the angle decreases the space between the tines when the rake is pulled forward, as well it angles the face of the tines to the outside. I little momentum keeps the material "flowing" down the tine row until it is deposited in a windrow. There is a post somewhere in the forums where a TBN'er posted pics of him using his rake on snow and its effectiveness. It will do this with loose or clumped dirt, gravel of any size-even pea gravel, snow...everything I have tried it on although I have never tried it this way on leaves, that might be more effective for me this way. When using it to collect and windrow material, it will not get everything since some of the material does pass through the tines but it does a very good job. With multiple passes with a weighted angled rake, you can scrape about anything down to the base material.
We had an unbelievable storm last year that left several inches of sleet that had the consitency of an ocean of small marbles. It ran down the slope of my pond bank and covered my driveway and a good portion of my front yard with 3-4"'. I tried pushing it with my box blade before it froze together in a layer of ice and it just flowed around the box like water. I used the rake on an angle and was able to eventually move the vast majority of it off the drive before it froze in to a sheet. It does a good job of collecting limbs as was mentioned by another poster. I use it to clean up my wood cutting and splitting area where saw dust, small limbs and large chips leave quite a mess. Honestly, I never use it without the blocks on it any more just because it makes such a difference on what it will grab and hold. With the leverage produced by the weight of the rake and the cider blocks extended so far out from the rear, it makes a decent counter weight for FEL work too. I also use it to groom our practice ball field instead of using the drag. I think it's a great tool with many uses.
/ Landscape rake question #11
I tried that with my LRC-60. The land I need to rake isn't real flat. I've had no luck at all with raking straw or leaves. Every time I crest a small rise, the rake dumps its load. (and going back to pick up the pile with the front-end loader was more humorous than productive.)
I've been pondering a floating top-link like the mower has, but haven't gotten around to actually making one. Jenkinsph's suggestion looks good, but pretty pricey.
/ Landscape rake question #12
Hey ShenandoahJoe,
Is the land your working wavy or bumpy? If the land just has a bit of a wave to it, you might try replacing the fixed side link with a length of chain..
I know it works really good when plowing snow with the back blade to keep the entire blade on the ground.
But if there are just a bunch of small "bumps" it might not work out too well.
/ Landscape rake question #13
I think the thing I like about the pine needle rake is it looks like it would be more forgiving on the lawn. I have a 7' landscape rake and would be concerned about tearing out to much grass. I will also try out the pine needle rake to collect rocks from the surface of freshly tilled soil after using my rock bucket to collect the 3" and larger ones.
I think for $350 it is worth trying anyway.
Steve
/ Landscape rake question #15
How about picking up Hedge apples (about the size of oranges)?
KC
/ Landscape rake question #16
When I use my rake to collect grass I just leave the 3ph lever in the down position and that allows the hitch to float. On my tractor it does anyway. Works well om my "wavy" yard.
2018 Nissan Sentra Sedan (A61569)
2018 Nissan Sentra...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61568)
1987 International...
UNUSED WOLVERINE M-SB42 42" MINI ROCK BKT (A62131)
UNUSED WOLVERINE...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2004 Chevrolet Silverado Pickup Truck, VIN # 1GCEK19T04E260216 (A61165)
2004 Chevrolet...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
