How much pressure in the JD Hydrostatic steering?
   / How much pressure in the JD Hydrostatic steering? #1
mars1952
Western North Carolina
1999 John Deere 4300 12/12 sync-reverse
Hi: I have a JD 4300 12/12 Sync Reverser. It has two hydraulic pumps one for the remotes and rock shaft (2500psi) and one for the steering. How much pressure does the steering pump put out? I have looked online and in my tech service manual to no avail.
Thanks, Marshall
   / How much pressure in the JD Hydrostatic steering? #2
I think it's the same as the main system pressure-but not 100% sure. Nothing in the steering section of the FSM?
   / How much pressure in the JD Hydrostatic steering? #3
In my tech manual for my 790 they have a section near the back that covers power steering relief valve testing. It's 1200-1400 psi for the 790.
   / How much pressure in the JD Hydrostatic steering? #4
The steering system on the 4300 is set to 1500psi, according to my
manual, p 9-8. The only diff betw the SRT and HST trannies is in yours
the steering output goes right to the tank, while in HSTs, the steering
OUT provides the charge pump flow.
Excellent! Thanks, I had look in the same book and couldn't find it. I was hoping that it was a low pressure system. I have a project that I would like to do that needs no more than 1500 PSI.
Thanks, Marshall
Ford Tractor (A50120)
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A54757)
INGERSOLL RAND...
JOHN DEERE 6615 TRACTOR (A54756)
JOHN DEERE 6615...
New Kivel Skidloader Double High Back Bale Spear (A50775)
New Kivel...
2017 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
