4n1 on a L3830 size tractor
   / 4n1 on a L3830 size tractor #1
_RaT_
Super Member
Peoples Republic of Northern CA.
Kioti 3510-SE HST
Anyone using one? What is the manufactuer? How much does it weigh. Did it take away significantly form the load lift ability. I ask because my association is buying a used L3830 HST and they have opted for a grapple system to pick up brush. I have not used grapples, only 4N1's. They have asked for my input. I would prefer the 4N1 but maybe the grapples OK. Just looks weaker. Thanks, Mark
   / 4n1 on a L3830 size tractor #2
If it is specifically for brush than a small grapple like the Markham LD-48 or the WR Long equivalent is the ticket.
Advantages are:
-lighter weight
-cheaper
-better visibility
-easier for a non-regular user to use
   / 4n1 on a L3830 size tractor #3
I have a L4310 - and a Shop Built Grapple - the 4n1 is too much for brush.
   / 4n1 on a L3830 size tractor #5
I have a a 48 inch grapple on a L3830. Works fine, I would think a 4 in 1 would eat up too much payload.
   / 4n1 on a L3830 size tractor #6
I would have thought a tractor that size would have no trouble with the extra weight of the 4in1. I think its a 'problem' that is often exagerated. In fact I don't think I've ever read any support for that comment from anyone who actually owns a 4in1.
I have a small tractor and a heavy 4in1 but it will still lift anything I can fit in the bucket, although you might need a little extra weight at the back end for traction.
I'd suggest you make your decision based on other reasons. Like what you really want it to do.
   / 4n1 on a L3830 size tractor #7
Sorry for my ignorance, what is a 4n1?
   / 4n1 on a L3830 size tractor #8
That is one on alchemysa avatar. Some times refered to as a clamshell.
   / 4n1 on a L3830 size tractor #9
You are right.
I have a heavy 4 n 1 skid steer bucket on my L4200. Never any problems.
When I bought the 4n1 I thought I wanted a grapple so I bought one of the big rock brush grapples...
After using my 4n1 I have NEVER used the grapple. It's still new, I can not imagine anything I would ever do that the 4N1 would not handle as well or better...
There are some that like their grapple but I think if they used a 4N1 for a while they would see that its a better tool. KennyV
You are right.
Thats kind of my thought. The reason for the grapple was to retrofit a very nice tooth bucket from our CAT skid steer and use it for brush. Use the stock Kubota bucket (with QA) for moving dirt etc. I would think that picking up stumps, logs and brush would work fine with a 4N1 plus the benefit of light dozing, back dragging type work.
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2019 CATERPILLAR 262D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
