790/300 Loader slowly lowers by itself
   / 790/300 Loader slowly lowers by itself #1
Twig52
Where do I look to find why my loader will slowly lower itself. If I park the tractor (790) with the loader raised, it will drop over a few hours time. Have to adjust while using tractor also. Creeps down while running or shut down.
   / 790/300 Loader slowly lowers by itself #2
Either the cylinder is leaking fluid past the seals on the piston or the spool valve seals are leaking. You may try using a floor jack or block of wood beneath the bucket to hold it in place while you unplug the hydraulic connections to the loader boom. Then back off the block or release the jack and see if it holds without leaking down. If it holds then the valve is the problem if it leaks down the fel cylinders are the problem.
Steve
   / 790/300 Loader slowly lowers by itself #3
It is perfectly normal to have "slow" leakdown. JD even has a published "acceptable" leakdown amount paper.
Also...parking with the loader up is not a safe practice.
   / 790/300 Loader slowly lowers by itself #4
What you posted is true but it depends on how fast it is leaking down when trying to do loader work.
Steve
If I am running the tractor and have 500 lbs in loader it drops about 1" per minute. Thanks for the replies so far. Have not had the chance to diagnose it further yet.
   / 790/300 Loader slowly lowers by itself #6
That sounds about like mine.
I think it's the valve. If it were the cylinder, it would most likely be one or the other and as it dropped, it would bind.
It is annoying.
On my center link cylinder, it has a check valve. It never moves.
   / 790/300 Loader slowly lowers by itself #7
My 790 used to do this as well. Nothing drastic, but a slow bleed over time. This is normal. My new 4120 actually has a hydraulic lock on it to prevent bleed down.
JOHN DEERE 6615 TRACTOR (A54756)
JOHN DEERE 6615...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
BUNDLE OF 96" X 40" DIAMOND PLATE SHEET METAL (A54756)
BUNDLE OF 96" X...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
