Eurocardan PTO shaft no longer telescopes
   / Eurocardan PTO shaft no longer telescopes #1
lilmatt
I have a Eurocardan telescoping PTO shaft on my Land Pride PD15 post hole digger. The digger was new this summer. I went to mount up and use the post hole digger today, and I found the PTO shaft no longer telescoped! It is stuck all the way in, or real close to it. As a result it won't reach my PTO, and besides that something's clearly wrong.
I didn't notice any trouble when I used the post host digger a couple weeks back, and nothing has fallen on it or driven over it, so that it could've been bent. I can't heat it as the shaft guard is plastic. Any suggestions?
   / Eurocardan PTO shaft no longer telescopes #2
Its either jambed or twisted. Soooo.
You might have put it together wrong (there's a subtle difference in the tongue and groove orientation). Or, its twisted a bit from drilling with a high power application.
In either case. You got it into that position. Now get it out. Take a 2x4 and cut a notch in it to hold the tractor end of the shaft. Then beat the board with a hammer or sledge until it extends. A little grease or graphite lube is always a good idea in a take apart pto shaft.
You stated that something else is clearly wrong but failed to say what that is. I wouldn't consider a stuck pto shaft to be a clear sign of wrongness. So what is that other observation? Are the U-joints broken?
The PHD dealer put the shaft together. I've only been able to see what's inside by looking that shaft up on the internet.
No U-joints are broken. I was just saying that if I _could_ reach the chuck to the PTO, I wouldn't want to run it since something's wrong (that being the stuck shaft).
I've got the shaft off the PHD now so I could bring it into the garage to work on it. I'll try your "percussive maintenance" suggestion. Thank you.
   / Eurocardan PTO shaft no longer telescopes #4
I have had that happen on older equipment I have bought for a good price and had to rescue..usually it had been left sitting for a time. Here is what I did and it has worked so far. back your tractor up to the equipment and attach a chain from your draw bar to the yoke just behind the spline of the PYO shaft of the piece of equipment and kind of pop the clutch on the tractor - you want to jerk it loose the shaft slides in a larger outer shaft and is probably stuck...at least that is what I have run into on two separate occasions and when it pulls out free you can squirt some WD -40 into the square opening on the receiver end and take a thin brush and get down in there and try to scape the edges of the interior walls ..get it cleaned out , then dean and lube the other end and slide them back together...worked for me..
   / Eurocardan PTO shaft no longer telescopes #5
I bet they are just rusted together...the dealer probably failed to grease it.
   / Eurocardan PTO shaft no longer telescopes #7
squirt liberal amt. of wd40 and let it soak overnight,worked for me. russ
2014 BMW X1 AWD SUV (A56859)
2014 BMW X1 AWD...
BARBED WIRE (A58214)
FUEL CELL TOOLBOX COMBO (A58216)
FUEL CELL TOOLBOX...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
4000-Gallon Water Tank (A58216)
4000-Gallon Water...
Club Car Electric Golf Cart (A57149)
Club Car Electric...
