=== BLADE HOOKS ===
/ === BLADE HOOKS === #32
Here is another photo of the blade inquestion.
I know it may sound odd but you could mount a couple of hooks to the cutting edge. If your only plowing snow it wouldn't matter. I'd rather have the hooks than not.
/ === BLADE HOOKS === #33
first of all- how high does the plow go up exactly ?
/ === BLADE HOOKS === #35
Not very high :mad: but he's not looking to lift with it.
Wish I had a loader mounted blade to push the snow up and over big piles.
/ === BLADE HOOKS === #38
Mr LBrown59
Isn't your blade spring loaded? I believe your blade would tilt if you put any pressure on the top of the blade to lift or pull.
Mr LBrown59
Quote:
Originally Posted by some zilch
as soon as you started to pull back with the blade, wouldnt it want to "spring over" just s if you hit something hard going forward while plowing?
I will have to put a chain on the blade and hook the other end to something and see what happens.
LB59__________________
/ === BLADE HOOKS === #40
Guessing about 10 to 12 inches.
Not really to concerned with lifting so much as pulling or draging however.
Ok - looks like I misunderstood your intentions. I can understand trying to lift something with plow if needed, or having a loop or hook to for lack of better way to explain it- to tow when stuck. I am just kinda bit horrified that towing would be done against the fast attach holding points. However- if the BX is stuck and front blade is on, and unable to tow from behind then I would say a hook perfectly centered low as possible would be ideal. Other then the brush gaurd, there is really no good place to place a emergency tow strap.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
More info coming soon! (A56859)
More info coming...
2020 Deere 544L (A60462)
2020 Deere 544L...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
