HELP PLUMBING SOLENOID VALVE
/ HELP PLUMBING SOLENOID VALVE #1
wildwillie
north Idaho
L3400,
I HAVE A NORTHMAN 3POSITION, DOUBLE SOLENOID,TANDEM CENTER SPOOL,12V SWH-GO2-C6-D12-10 WITH DO3 BASE FROM NORTHERN TOOL. CAME WITH NO INSTRUCTIONS JUST THE LETTERS APB ON ONE SIDE AND T ON THE OTHER SIDE. I ASSUME A&B GO TO THE CYLINDER, P IS FOR PRESSURE AND T IS RETURN TO TANK. NOW DO I JUST INSTALL A T IN THE LINES AT PB FOR THE FELL? I AM ADDING A GRAPPLE AND SNOW BLOWER WITH HYDRAULIC CHUTE ROTATION. TRACTOR IS L3400 KUBOTA WITH FEL. I WOULD APPRECIATE ANY INFO.
/ HELP PLUMBING SOLENOID VALVE #2
First, PLEASE STOP YELLING AT US:D Typing in all caps is considered yelling and it's also very hard to read.
THIS is a link to the valve in question.
A and B ports do go to the cylinder-they are your "work" ports.
P is for Pressure or IN
T is for Tank or OUT
Now, You CANNOT Tee into the PB line from the FEL valve. All valve must be added in series. Adding the valve with a Tee will cause the fluid to bypass it because like current in a electrical circuit, the fluid will take the path of least resistance and bypass the new valve.
You need a hose from the PB port to the P (IN) of the solenoid valve, then the T (OUT) will connect back to the hose you removed form the PB port.
SO THERE IS NO NEED FOR A RETURN LINE ON THE VALVE IF IT IS IN SERIES ? THE PRESSURE RUNS THROUGH THE VALVE
Thanks for the advise. See even us north idaho red necks can be learnt stuff.
/ HELP PLUMBING SOLENOID VALVE #6
AAAHHH, Reading that does not hurt my eyes;)
Just to clarify, you only need a separate return if you are using a valve that has PB, and in your case the solenoid valve does not. Just plumb it in series on that PB hose from the FEL valve and you will be good-to-go...and you will only need 1/4" hoses from the work ports to the blower.
/ HELP PLUMBING SOLENOID VALVE #7
I am watching this post very closely and will be doing the exact same thing. Kenny D:
Why do our loader valves have a non-pressurized return line, and the Northman solenoid valve does not? Is this so when you have the loader in "float" that the excess fluid can return?
/ HELP PLUMBING SOLENOID VALVE #8
When a valve has a PB port (as do most loader valves) then the "waste" fluid from the work ports goes to the OUT line, with the remaining flow that the work ports do not use continuing through the valve's PB port to feed the next valve in the series.
Valve's without a PB port (or a PB port that's plugged) only have (or use) the OUT port, the "waste" fluid is mixed with the flow from the pump.
So since the solenoid valve does not have a PB port, then just IN and out ports are used.
Clear as mud?:D
/ HELP PLUMBING SOLENOID VALVE #9
My translation: One less hydraulic line to purchase!! I like it already!
/ HELP PLUMBING SOLENOID VALVE #10
It's strange that most manual valves "must have power beyond" if there is any downstream valve such as the 3ph control but these solenoid valves don't have it and everyone hooks them up in series as described above with no ill effects. As long as there is a valve upstream with PB and a relief to tank I personally don't see what it can hurt. I'm getting ready to do the same thing for my own grapple project.
Brad
/ HELP PLUMBING SOLENOID VALVE #11
I believe technically, that all OC valves could be connected in series. The first valve upstream would have priority. However, if the up stream valve is only using say 5 GPM out of the 10 GPM available, then the other 5 GPM would flow downstream. You would have to be careful about deadheading a valve, and a relief valve across the pump would be advisable. Also in a series circuit, if the last valve is used, then all hoses and valves up stream are pressurized.
This would hold true for electric valves also. The fluid flows trough them if not being used.
Has anyone found a source for a good momentary switch that I can mount on the fell control .I can find rocker switches but need some sort of housing.
/ HELP PLUMBING SOLENOID VALVE #15
Thank you Kennyd,, I'v read most every thread on how to plumb in another valve... :D and the way you explained it to wildwille hit the spot,, "power in unused power out" = series..
Thanks,,, hr3
/ HELP PLUMBING SOLENOID VALVE #16
Thanks,,, hr3
You are welcome HR...
This site is invaluable, Thanks to all. I went to my local A.T.V. dealer yesterday and found a great two position momentary switch ,in a water proof housing, wired, and with a bracket to mount to my F.E.L. lever. It is meant to be used for a winch, best of all it cost $20.00
/ HELP PLUMBING SOLENOID VALVE #18
Cool! A Picture, Manufacturer and Part # would be good info for all...
Here is a picture of the switch part #2875957 ATM -SWITCH,WINCH from Honda ATV dealer.
