Grading BOX BLADE
   / BOX BLADE #1
stev0000
Hi can anyone help me with advise on a box blade .My kubota dealer is giving me
a deal on a bush hog box blade sbx66 its 520lbs. Is that to big for my b3030.
   / BOX BLADE #2
No, I don't think that is too big. My box blade is 495# on a smaller tractor and I know it's back there but it's not too much.
   / BOX BLADE #3
I've got a Woods 60' box blade on my B3030HSDC and now wish I would have gotten the 65-66".Go for it!
   / BOX BLADE #4
I am running a 60 inch in a little 25 hp tractor with good results.
You have a loader on yours so that will help with the front wheel traction if it becomes an issue
   / BOX BLADE #5
Your tractor manual will tell you what size and weight is the max for your tractor.
   / BOX BLADE #6
For really hard dirt work, I always end up adding almost 200 lbs to my 300 lb 48" box blade to help it bite better. I would think weight in this situation is a good thing.
Sounds like everyone is saying the width is not too much. In my mind, that would be your primary limiting factor.
   / BOX BLADE #8
I thought that was what the scarifier teeth were for.
Ken
   / BOX BLADE #9
I'm not so sure I agree with everyone suggesting buy it. A 66 inch boxblade will place a whole lot of drag on your 3030. Drag that the Kubota doesn't have enough weight to overcome. Weight of the boxblade is not the issue, weight of the tractor to provide adequate traction is. I believe a 60 inch is ideal for the 3030 unless you're moving some soft soil.
Then again the other hand, if the price is too good to pass up, try it.
   / BOX BLADE #10
My B2910 (earlier B3030) handled my 60" KK easily, wished for more width such as 66". Now I use the 60" on my peewee JD2210 and it suits it perfectly.
2024 Schulte 5026 Batwing Rotary Cutter (A56435)
2024 Schulte 5026...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
2017 Ditch Witch FX50 (A55973)
2017 Ditch Witch...
2019 GALYEAN...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2017 JOHN DEERE 323E SKID STEER (A52709)
2017 JOHN DEERE...
