Tire Ballast
   / Tire Ballast #13
Hmmmm, my new tractor came with "Calcium filled" tires front and back for ballast....im assuming its Calcium Chloride.
Now Im worried.
being a newbie to Tractors, it seemed to make sense to me that Ballast & Safety were a good thing, Dealer never mentioned anything regarding the down side (and I didnt know enough to ask).
Dealer indicated it was a common thing, so i went for it :(
   / Tire Ballast #14
It is common.. because it's about the cheapest ballast you can get.
if you have tubes.. you are fine.. if they leak.. clean them up and keep the rims painted.
if tubeless.. watch them. I personally don't like loaded tubless tires.
soundguy
   / Tire Ballast #15
Now Im worried.
Just being in the same parking lot with a tire being filled with calcium-chloride is enough to sit up nights about.
If you are at all familiar with the genuine tank bluing process for firearms, then you know about the bluing salts "creeping" over the sides of the tank and corroding everything in their path; plus, when the gun parts are removed from the bluing bath, they have to be put in a neutralizing solution to kill the corrosive salts.
Calcium-chloride is easily ten times more corrosive than the gun bluing salts; once it gets on metal, there is no getting it off.
Calcium-chloride is road salt in it's strongest form and we all know how quick road salt will dissolve a set of frame-rails.:cool:
   / Tire Ballast #16
Now Im worried.
only time you have to worry is if you have a leak, I doubt they are tubeless. I had a problem because I believe the previous owner let the leaks go so the inside of the rim developed rust. even though the tire guys ground them down I think the surface of the inside of the rim wore out tubes. CC is highly corrosive so just watch for leaks and repair them quickly.
   / Tire Ballast #17
Calcium-chloride ..... once it gets on metal, there is no getting it off.
Pure bs...
you can wash the metal down and remove the salt.. it does not magically bond with the metal
soundguy
   / Tire Ballast #18
usually once you have pitted metal.. it's good to prime than paint them.. and then if really bad.. boot them. Not unheard of to roll out duct tape on the inside channel of a pitted rim.
soundguy
   / Tire Ballast #19
soundguy
I agree, but at least me when you have a tire repair guy out it was tough to do much with them that requires time to dry, etc. If you could take the tire off yourself that would be different.
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
2011 DODGE RAM 2500 (A50854)
2011 DODGE RAM...
More info coming soon! (A49346)
More info coming...
1995 CATERPILLAR 621E (A50854)
1995 CATERPILLAR...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
