425 Steering Hose Replacement
/ 425 Steering Hose Replacement #1
catsco
Gold Member
Colorado
PT425
I knew it had to happen, just didn't think it would be this soon.
For nearly 300 hours, I've seen a very small seep (oily film after 10 hours after pressure washing) from one of the hoses to the right side steering cylinder. I'd tightened the fitting, but didn't want to overtighten it.
Yesterday, while a friend was moving some logs, oil started spraying out, and he discovered that the leak wasn't at the fitting, but at the point where the one hose is zip tied to the other to keep it out of the way when turning to full lock.
Our only local source (within 20 miles) is NAPA, and they only had 5000 psi hose with fairly large fittings. The hose isn't very flexible, but worked for this location.
The downside is that the 36" hose cost nearly $40!
I'm going to try to find somewhere not too far away to have a spare made for the steering and lift hoses, all of which are the same length.
I'm posting this to caution against relying on PT for information for some things - I wasn't there, so I called PT and was told that the hose was 32" long. It was actually 37", so I almost got one too short - had my friend remove the old one with some difficulty at the remote location & call me to verify.
To their credit, PT said that getting a hose locally would be much cheaper, but didn't give me their price.
So - my question is: Online I see a lot of much lower cost hoses w/5000 psi rating, but the originals are 3000 psi. How can I make sure that I'm getting the thinner more flexible ones where the others won't work. Online suppliers show 2 & 4 wire, but no one seems to have actual OD listed. The 5000 psi one I had made wouldn't work in many places where a much tighter bend is needed.
Thanks!
/ 425 Steering Hose Replacement #3
JJ and Wayne County can give you all the gritty details on hoses. Napa had only a 4 wire hose for my wheel motors (3/4") and man that was a bear. Also, there are different kinds of ends for hoses, and I found PT made many design concepts based on a shorter end version (that my NAPA did not stock). I drive about 35 miles for my hoses as I pick up other stuff (Woods Logging has the coolest T-shirts and the guys who hang out there are pro loggers so an interesting crowd for me to hang with), but I found a bunch of places locally (Like machine shops) that made hoses but did not advertise the fact.
/ 425 Steering Hose Replacement #4
/ 425 Steering Hose Replacement #5
Your best bet is to take you old hose in to the hyd supplier, and go from there. You can ask for a more flexible hose that will handle the same pressure. You may be able to find one off the shelf, at a TSC. You can also get the reusable fittings and make up your own hose.
/ 425 Steering Hose Replacement #6
I have had the misfortune to replace two hoses. One split soon after taking delivery and in the second case, I crushed a hose fitting while attaching the backhoe.
In the first case I removed the hose and took it to a hyd shop. In the second case, I called around the local auto shops and found one that made hoses. Both jobs were reasonably priced and quick. They were NOT Parker brand as came off. The Hyd fluid did not seem to care as it stayed inside the replacment hose.
Tim
Thanks, JJ - my post came about because in the midst of a few million people along the front range of Colorado, the small NAPA store is the only source within 30 miles and has exactly ONE type of hose, the 4 wire way-too-stiff one.
I did find (on a trip to the nearest city) a Parker store which was about half the price, but still twice the price of other internet sources listed.
Thanks for the help everyone!
PS - I'd love to shop at TSC, but none within a reasonable distance.
/ 425 Steering Hose Replacement #9
Please tell me you are joking. I think I would go back there and ask again. If they are going to carry only one type of hose, it will always be 2 wire.
If I were you, as long as you know exactly what you want, I would pm Hydraulic Hose Guy. I think his name is Ken, from Discount Hydraulic Hose. Ask him to read this thread. I am sure he will suggest 100R16 hose.
Parker, Weatherhead, Gates, Aeroquip, you won't really notice much of a difference between your major hose manufacturers as far as serviceability goes. I have my preferences based on their outer coating and crimp fitting configuration.
Andy
Oh, BTW, maybe PT meant 32" of hose, then the crimp fittings, not 32" OAL.
/ 425 Steering Hose Replacement #10
yes, the list i saw was hose length, not overall length. Unfortunately, fittings vary in length.
Ken
QUOTE]
I wish I were joking. The O.D. of the 4 wire (they have about 25 ft. of their only roll left) hose and it's fittings is almost to large to attached the ends to the steering cylinder. Looks odd, but works.
All of a sudden, or maybe not so suddenly, another steering hose and the three lift hoses (excluding the one I just replaced w/the Parker store hose) are seeping.
Looks like 750 hours is the magic number for hose life on my 425!
/ 425 Steering Hose Replacement #12
Are you getting any chaffing or excessive flexing in these hoses that is causing this early failure? Looking back at your first post you say the weep is at the point where two hoses are tied together in a high flex position. Maybe the hose length is too tight or some chaffing gear is needed. Any kids of solvent or unusual exposure to UV radiation such as from a welder?
Perhaps these are useful thoughts.
Brgds,
tim
/ 425 Steering Hose Replacement #13
Got the latest issue of Machinery Lubrication magazine and noted an article about Hydraulic hose Contamination. In the article was a paragraph about Multi-plane bending.
This is defined as the hose bending in more than one plane that results in the twisting of the wire reinforcment. A 5 deg twist can reduce life by 70% and a 7 deg twist can reduce life by 90% of service life.
With the articulation of the PowerTrac and the fixed clamping of the hose, the hose may be subject to these internal stresses. Might expalin the 750 hr MTBF you've experienced.
Brgds,
tim
Great info...thanks!
That would explain why the failure was where it was.
The hose was also tightly zip tied to the hose from the other end of the steering cylinder, so the end of the crimp fitting was chafing where it couldn't be seen.
The lift cylinder hoses (at the cylinders) and the steering hoses (also at the cylinder) are weeping a little. Takes about 5 hours to see any oil film after thorough cleaning of the area.
The only other hose that has weeping is on of the oil cooler hoses - probably the longest one on the whole tractor, and under all the other ones in the main body tub.
Ones that have no movement seem fine.
UV isn't a factor as the tractor is stored inside, but the 4.5 years, extreme temperatures (120 deg. in storage during summer to -25 deg. in winter) are probably also a factor.
/ 425 Steering Hose Replacement #15
Tim,
Great point. Another reason why I always suggest people get a hydraulic hose catalog and skim through it periodically. It is all in there. When Installing a hose, I always try to install it with the layline (writing on the hose) facing so I can see it for the distance of the hose. That way you know it's straight. Also a good idea to use 2 wrenches when installing a hose, one to tighten the nut and the other to keep the hose from twisting.
It seems like your PT's hydraulic systems get a lot of pulsing. This will shorten hose life. Try to have your hoses clamped down, ty-raps aren't good enough. Also remember that the hose shouldn't start bending until it is 1.5x the outside diamater away from the crimp. I also like 100R16 hose for applications like this, it takes pulsing better than your standard 2 wire 100R2 hose.
Andy
/ 425 Steering Hose Replacement #16
I just had my tilt hose rupture while using the mini hoe, spraying oil at the cab area of the tractor. Fortunately, i was wearing safety glasses at the time so the oil got on my glasses instead of my eyes. Just a reminder that safety items are for the unexpected events. With all of the hydraulic lines right in front of the PT's, wearing glasses is a good idea, especially when using the FEL or attachments. Today's incident certainly will make me wear them more.
Andy, the hose was 100R17, not sure if it was original to the tractor or not. Nice bending radius but 100R16 also has a nice bending radius. The auto parts hose place made a hose with 5000 psi rating so either 100R2 or 100R16. 100R16 does not have as thick a cover as 100R2?
Ken
/ 425 Steering Hose Replacement #17
Wow, 100R17 is a 3045 psi hose! Used where a small bend radius is needed. Interesting.
Yes, 100R16 hose has half the bend radius of equivalently sized 100R2 hose. Also a thinner cover, and cheaper! To me, 100R2 is a dinosaur. I would only use it if I couldn't find anything else. btw, 100R16 and 100R17 have the same bend radius. 100R17 is a weird hose, is that a factory PT hose?
Was your 5,000psi hose 1/4"? If not, what size was it? The 100R# should be plainly visible on it, I believe it's a requirement that it be clearly labeled but I may be wrong.
Given the PT's layout that puts you close to the work, safety wear would probably be a good idea. You might try the plastic wrap on your hoses. This would help keep leaks contained. It can also be installed without removing the hose.
/ 425 Steering Hose Replacement #18
Dear WCH,
I assume that you don't mean Saran(Tm) wrap...What did you have in mind?
Thanks for the helpful comments!
Peter
... You might try the plastic wrap on your hoses. This would help keep leaks contained. It can also be installed without removing the hose.
/ 425 Steering Hose Replacement #20
Dear WCH,
Peter
Actually, Saran tm Wrap is too expensive. I go for the Great Value stuff in the 250 yd roll. You can get the smaller roll if space is an issue.;)
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2021 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2021 Caterpillar...
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
84in Bucket Skid Steer Attachment (A61572)
84in Bucket Skid...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
