Builder
Super Member
- Joined
- Feb 22, 2006
- Messages
- 6,155
- Tractor
- Kubota, AGCO, New Holland LB
Trust me on this one, your cylinders do not have relief built into them.![]()
yeah, after plowing snow for ~25 years what would I know.
yeah, after plowing snow for ~25 years what would I know.![]()
Business. As you may or may not know I am a Corporate Pilot and I am flying in some of our people for a meeting. We are landing around 1:45 and planning on departing around 4:45 to Saginaw Michigan where we will overnight.What brings you to town?
I would say i would meet you and buy you a beer but I am booked for Monday.
This week has me very busy with 5 stops on Monday taking me as far east as New York. Tuesday I am off to Wooster Mass, New York, Philly, Cleveland, then Home. Wednesday I am off to Fresno Cali where I will overnight. Thursday off to Seattle to overnight again. Then Friday returning home.
Chris
Sounds like a crazy schedule.
Let me know the next time you are in the area. This is just a crazy time of year for us.
I really like 4 shorts set-up too. I like the shortening of the plow frame and I don't want to take anything away from his work except one little thing: I don't like the rams under the mounting plate. They look really close to the ground and succeptable to damage.
I know I'm going to get whupped-up on for suggesting that, and his is a better set up than mine, but I wouldn't feel secure about the rams being that close to the hardtop and I like having my QA plate free for other uses.
Might be able to cure this with skid shoes on the back.
Flame suit zipped, Kevlar vest on and high top steel toe boots with metataursal protectors tied.![]()
Where are you getting them for $50? Best I have seen is around $85 one Ebay. I have to replace both of them on a plow I picked up on CL for $80.
Chris
4 shorts,Builder my friend you made a good point on the rams but there better off under the frame than on top of it. I've had lumps of hard snow come over the top of the blade that would have taken those rams out if they were on the top of the blade frame. Have a look at the first picture. Yep, rear skidsLast winter I also added side Super Nova LED strobe lights to the system so when I'm backed into a driveway and my blade is out in the road vehicles can see the blade much easier. It's nice to see some of you like my design
It might not be the design that fits everyones needs but it sure works for me.
Oh and as for the relif valve. I've got 13 years with that plow on the front of a 1993 GMC truck and one year with it on the front of the Kubota and when I've hit something side on it worked the exact same way which makes me that the hyd's on the tractor has something there to make the pressure by-pass if It needs to. I can only report on how it worked for me last winter and I'm more than pleased with the set up.
Plow in action:
YouTube - Kubota at night
4 shorts,
The strobes are a great idea. The worst part of plowing my drive is at the road. It's a blind drive and drive itself is lined with trees so hanging the blade out there is always a concern. Very nice work, as usual.
4shorts said:Oh and as for the relif valve. I've got 13 years with that plow on the front of a 1993 GMC truck and one year with it on the front of the Kubota and when I've hit something side on it worked the exact same way which makes me that the hyd's on the tractor has something there to make the pressure by-pass if It needs to. I can only report on how it worked for me last winter and I'm more than pleased with the set up.
You've put way more thought into your plow than mine. Your's is a work of art, mine is just something I threw together. I bought a $400 meyers plow and a $120 mount plate then welded mounts and a hook to it. Yours is much more customized and you did a great job. Believe me, I'd rather have yours, but for the small amount of plowing I do these days, mine works fine. I am mounting skids on my mounting plate this fall and that's all I really want to put into mine.
That's what I thought, too, but don't tell Duffster that.I have a bypass relief valve sitting in my shop I could use, don't know if it's really worth the time.......
Duffster is right about the fact that there's no relief valve in those rams. I've had them apart many times and there just a regular cylinder inside. I do think that my system has some sort of by-pass in it because if I hit something the blade will give and you'll notice the cylinder move in slightly.
I try and put as much though into things I do and I hate having to do things over the second time. It's cheaper to do it right the first time if possible. I use my system commercially so I don't want trouble in the middle of a storm and not get a lot cleared for my customer. Having it look pretty, well that's just a bonusSometimes the only difference in a good looking plow and a great looking one is a flick of paint
4shorts.. Just watched the video. (aren't Iphones great). I would love to soo it in the daylight. Also, if you have a blower on the back, why the blade on the front?
Wedge
Maybe you two oughta get a room together swap plow stories and compare meyers plow cylinders???![]()
j/k couldn't resist. You said the same thing about me!
I paid $80. each up here in Newfoundland last winter. Keep an eye on the bolt holes when buying them. I've seen them with differant sizes and you might not notice it until you go to install them.
Thanks. I ordered some off the net for about that. Around here they want $187.50 per cylinder. I guess the guy with the plow shop thinks no one can use the internet to get anything.
Chris
