ATV or UTV ?
/ ATV or UTV ? #1
robertwhite
Here's the predicament I am having.........
Mini Farm (15ac), all flat, half field, half lawn.
I was seriously considering getting a Kawi Mule 4010 (or similar other brand), preferably in the Trans 4x4 (convertible) model.
Then I started to think about just how difficult it would be to dump a load of dirt, rock, logs, whatever without a hydraulic ram or at least an electric one. Looking around the net, I see hydraulic kits in the $800-1100 range :eek:
They are also in the $10K+ range.
So.................. I asked myself, what about getting an ATV (700-750cc) and then just picking up an ATV trailer which are easily had for $500-1000 depending on weighted or hydraulic lift. A new '09 Yamaha Grizzly or Kawi Brute is right at the $7K point. Add the 2 costs up and it is actually less to get the ATV (which can be played with in the fields, trails, etc.) and the dump trailer which is easily separated and stored.
Now obviously, the UTV is easier to get into tight spaces, but the property is pretty much wide open and getting around trees and such is not an issue. I also have no need to fly thru the fields or roads at 50 mph, so the ATV will be used as a workhorse.
So the question is, How much real world use will I gain or lose in either scenario?
/ ATV or UTV ? #2
I have used either an ATV or my tractor with FEL to move or haul stuff or tools around our 11 acres for a number of years. It worked ok but when it was time to get a new ATV I decided to move up to a UTV. After pricing the new ones I started looking at used with low hours. There are a lot of them on the market right now. Most at 25-40% below the new prices even with low hours. I ended up going with a Kubota RTV 900. I did not get the power dump bed as did not deed it. I actualy passed on one with 700 hours in the same price range of the unit I ended up buying but a broker was selling and did not have much history on the unit.
The Kubota is more of a work vehicle and there are other brands with more speed. It does fit my needs quite well. I like being able to haul tools, feed and even a grandkid along without overloading a ATV or having to tie everything on the back.
/ ATV or UTV ? #3
I used to use a dump trail with a garden tractor until a got a Kubota RTV500. It is so handy having the bed right on the vehicle. I worried about dumping a fully loaded UTV bed as well and was planning on adding an electric lift until I actually tried it with a load. On my RTV500 if the bed is fully loaded it is easy to dump by hand. I posted these pictures previously of my wife dumping a full load of dirt. However, if you load a few rocks in the front of the bed, then you cannot lift it unless you roll the rocks to the middle or back of the bed. As long as you can keep the load distributed in the bed, then there is no need for a lift.
/ ATV or UTV ? #4
I kind of loaded mine a bit heavier. I've posted this before, but here is my RTV900 with close to 2000 pounds in the back. My little helper loved to pull the 'dump' lever when it was time to dump. To save my lawn, I used the RTV to fill the edges next to where I concreted my driveway so there wasn't an 8" drop from the driveway edge. I literally made a couple hundred trips and dumped loads like this with the RTV. Never had an issue and it always dumped the load.
/ ATV or UTV ? #5
I have owned both,2003 Kawaski 400 atv,2004 kaw.3010 mule 4X4 and now my 2006 kubota RTV 900 4X4.My choice hands down would be a Kubota RTV 900 or 1100 models and then the Kaw. mule.coobie
/ ATV or UTV ?
Stonehaller: Does the 500cc have enough "oomph" or does it feel underpowered at times? Mind telling what it cost you?
I looked at the specs of the Kubota machines vs. the other well knowns and the specs look impressive. Question is do the specs pan out in the real world?
Don't know if I will be able to get away with a 500cc, but there are no real hills on the property.
900cc cost? (dealer sites nor Kubota site lists pricing at all:()
What say the masses?
/ ATV or UTV ? #7
If you have any plans for recreational use, go with a Polaris ranger, or a atv. The Kubota seems like more of a workhorse and not so much something you'd take trail riding.
I'm going through the same decision you are right now, but i've pretty much narrowed it down to a Honda Rubicon Atv. Solid axle, beefy and dependable workhorse small enough to navigate our trails to get firewood. Plus the price difference was the real issue, a new Rubicon is about 6300, the rtv 900 is WAY more expensive (but its also alot more machine). As far as atv's go, i've done alot of reading lately, and even the people that ride Yamaha's, polaris, kawi, say the honda atv's are where its at for farm use, but mudding go with anything else.
/ ATV or UTV ? #8
Hey...Honda' love the MUD....just look!
Let me tell you something, they ALL get stuck! Its the winch that counts when forging the mud holes.
I wouldn't trade my Honda's for anything. No belt, no problems. Seen way to many belts get wet, muddy and swamped and then have issues. I'll take the hydro tanny or manual anyday over a CVT.....
Craig
/ ATV or UTV ? #9
I can go along with that statement. The Kubota is definitely more suited for heavy work. I do have a Suzuki 750 King Quad with 27" 589 tires on it. I have to admit that it's been pretty dang good on the trails, in the mud, in the snow and climbing hills. There again, it's the first ATV I've owned that has been fuel injected. That makes it soooo much nicer! Oh, I do have a nice 3500 pound winch on it that I have used. It goes really well but, as previously stated, they all can and will get stuck.
/ ATV or UTV ? #10
Wagons are not very handy. They shake everything off and are easy to turn over. They are a pain to back up and to get in to tight places. Although I do have an ATV wagon I rarely use it. I'll use the pickup truck or FEL rather than the wagon. We do love our ATV's. We have two. A Honda Rancher and a Polaris Sportsman. Both are very good ATV's. For us it is better to have an ATV. We sometimes use these things in mud and snow up to the axles. They go right through it. UTV's don't do as well as ATV's in the slop. But if the only choice I had in hauling was between an ATV with a trailer and an UTV I would for sure go with the UTV.
/ ATV or UTV ? #11
The RTV500 is a definitely wimpy at or near max. speed. It will do 25 MPH on the flat, but any hills slow it down. In low range it is a tank - you cannot stop it. I have dragged good size logs out of the woods in tight areas where I cannot fit my tractor. I am quite happy with it. Cost was $7800 before tax.
/ ATV or UTV ?
I am going to look at the RTV's on Monday but in all the reading I have been doing it sure seems that the RTV500 is just barely adequate on hills with any kind of load. I am not looking for a speed demon (either the RTV or Mule) but I really don't want to be wishing it had more power after I purchased it.
Anyone have a Mule 3010? If so, how would it compare to the RTV500 under load on hills?
/ ATV or UTV ? #13
The Mule 3010 is more like the RTV900 in size. The Mule 610 is comparable to the RTV500. I went with the small vehicle because of the narrow trails that I have. If the size is not an issue, the larger vehicles are a better value.
/ ATV or UTV ?
Physical size yes, but engine size on the 3010 is only 617cc. A Mule 610 is only 401cc. Physical size is not a concern of mine (although for others such as yourself it may be), but engine size and the ability to go up a hill or pull a load is a big concern.
I am going to have to see an RTV in person to compare.
/ ATV or UTV ? #15
I had test drove both the 610 and the RTV500 and thought they were similar in power. Remember the hydro trans of the RTV, though more heavy duty, is not as efficient as the CVT belt drive of the Mule 610 which may be why it gets away with a smaller engine. I drove a used 3010 before either of the smaller UTVs and remember it had more performance and better ride then either of the smaller UTVs. It is hard to tell real world performance from just a test drive. Hopefully some 3010 owners will chime in here.
Even in high range, the RTV500 has good power if you go slow. I have towed my 21' boat in and out of the barn up a small grade in high range. The engine and trans do a go job at lower speeds. It's above about 15 MPH that it could use more power.
/ ATV or UTV ? #16
I know it probably doesn't count, but I had a Mule several years ago. Back then I had a JD Gator when their strongest model was the 4X6 with no suspension. To be honest, I liked both of them, the old JD Gator and the mule. The big difference was that my JD Gator was the yellow colored diesel powered 'Worksite' Gator and the Mule was gas powered. Neither broke down on me and I worked them hard. Again, it's been a while since I directly compared them, but the RTV900 was heavier built than a comparable Mule in early 2004.
I've had countless Odysseys, Gators, off road go carts and one Mule and two RTVs. I now have an RTV1100 camo. I just don't particularly care for the bright orange color and I don't like being hot/cold and bug bitten when riding around my property. The cab on the RTV1100 is particularly nice but expensive. One thing I did on both the RTV900 and the RTV1100 is add a 'coast valve' to make them drive very similar to all other machines and not have that sudden stop when letting off the throttle. I'm quite certain that there are a lot of quality machines out there. I just prefer diesel (fill up at the barn tank) and I've worked the Kubota RTV machines extremely hard with no ill effects. Again, others may do the same. I don't know. I'm more of a 'if it isn't broken, don't fix it' kind of guy. Therefore, I've stuck with the RTV machines.
2014 Ford F-550 4x4 Versalift SST40EIH-01 40ft. Insulated Bucket Truck (A64556)
2014 Ford F-550...
2007 JOHN DEERE 350D LC EXCAVATOR (A65053)
2007 JOHN DEERE...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
1996 Polar DOT 407 8,500 Gallon Single Comp Insulated T/A Diesel Tanker Trailer (A64194)
1996 Polar DOT 407...
3PT SPRAYER RACK (A64278)
3PT SPRAYER RACK...
