two_bit_score
Super Star Member
- Joined
- Dec 22, 2008
- Messages
- 12,598
- Tractor
- John Deere 110 TLB, Diamond C 19LPX GN trailer
well, maybe he wasn't going too far
What??? No comments on the lack of PTO shield?
Not enough .I weighed my truck trailer tractor with hog, but without front loader. My weight was 14,140. Do I need a trailer brake or 2. Yes I plan on putting one on the rear axle someday. If you pay attention to what you are doing then you can stop without fear of running someone over,, BUT an emergency stop may not give you the room you need to stop.
Word! For the price of a set of brakes, you wouldn't even be able to cover a month's insurance if you have an accident without them. Some states have installed heat sensors at the weigh stations to catch vehicles with faulty/no brakes. And atleast one state has a Mandatory brake inspection stop station for trucks/trailers. Don't remember how many trucks I saw this last trip with smoking brakes in WV and VA.Not enough .
put brakes on both axles.
I'd guess a good DOT cop would find it fails an inspection. That isn't going to be a 2 5/16" ball so he likely has an overloaded hitch. Next would be the axle loading of the trailer front axle. And that is a lightly built trailer for a 7K rating. Note the trailer hitch frame stops before the axles. Might only be a 5K trailer.Hey, that is my truck! Na, just kidding. I am not a JD man. Anyway according to TractorData.com that 3320 weighs 3,570# and giving 700# for the Loader and another 700# for the Cutter would put him just shy of 5,000# load. The trailer weighs about 1,300# so he is not overloaded and he does have brakes but he is obviously not distributing the weight properly. The trailer is just too short. And like you mentioned he needs a better draw bar or even just a Weight Distribution hitch.
Chris
I just saw this today. The pickup had a DOT number on the door. He had a
FEL up in the air resting on a homemade FEL stand, over the rear of pickup. At least he is using chain a binders pulling it forward, no other method of tiedowns. He also had a bush hog sticking out the back as well. The hitch ball looks like a 5 or 7k rating maybe ? I am not sure what he hobbled together to make the chain longer in the middle.![]()
That truck is a 2 wheel drive and was not sagging one bit. It is setting level. Switching the ball mount around would not make the truck sag but moving the tractor forward on the trailer would do so. Remember we are talking about a Ford here, not a Cheby!
Chris
the reason why the arse end of the truck isnt saggin is id wager he only has about 100lbs of toung weight on that thing.
point is there is no way he can the tractor far enough forward to get the 700 ish lbs of toung weight he needs.
and lets be honest there is no way the tractor is falling off the rear. If anything, it's going to slam into the back of the truck and then he deserves whatever he gets for not tying it down right.
I too am amazed at how people will spend 10's of thousands on trucks and trailers and pull a POS trailer behind. I'm exactly the opposite. In years past I've had POS for tow vehicles and spend all my money on the trailer. Even now the trailer out values the truck thats pulling it. Thats about a 30K worth of tractor there on a light duty landscaper. Jeeeeeeze!!!I just saw this today. The pickup had a DOT number on the door. He had a
