=== BLADE HOOKS ===
/ === BLADE HOOKS === #11
If you weld them on - be sure and keep them INLINE with your loader's arms. It is the strongest location. Welding on outside corners is not recommended - you need to keep the load centered or you could risk twisting your loader, especially if the load shifts.
Good point. Also keeps tractor from tipping.
/ === BLADE HOOKS === #12
well- having hooks on the blade could be useful for something I guess, but there not loader arms, just the fast attach. I think the top of the front blade should be reinforced and have a SINGLE hook in the center. This would prevent too much twisting and allow him to lift a small branch :)p) and move back with it.
/ === BLADE HOOKS === #13
How much lift and strength do the front blade arms have? I'm envisioning a fairly simple structure designed for pushing, not pulling and probably not designed for lifting much more than the blade itself.
Front end loaders are designed fairly heavy to do lifting, pushing, back dragging, etc.
Of course I'm sure it depends on the design of the particular machine.
/ === BLADE HOOKS === #14
assoon as you started to pull back with the blade, wouldnt it want to "spring over" just s if you hit something hard going forward while plowing?
I will have to put a chain on the blade and hook the other end to something and see what happens.
/ === BLADE HOOKS === #16
Good point.
Chris
/ === BLADE HOOKS === #17
LB; you will have to install hooks to whatever you have on the ft. of every BX you have in order for this to work as you have planned.
/ === BLADE HOOKS === #19
usually i dont question why some OP wants to make some mod. after all its not my junk so what do i care.
but honestly i cant think of one good reason to have hooks on the front of a snow plow. (although i can think of a ton of bad reasons of why not to)
my suggestion.
dont waste the time and effort to do it.
/ === BLADE HOOKS === #20
I picked up an almost new Curtis plow last summer,, It had a hook installed on the top center of the blade,,, It was kinda handy to lift the plow up and put it in the rack for the summer.. Not too sure what else i'll use it for ..
As for the "junk" coment :(
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
TANK MANIFOLD (A58214)
M998 (A55852)
M998 (A55852)
TULSA WINCH (A60736)
