Need small diameter grease gun head OR longer fitting
/ Need small diameter grease gun head OR longer fitting #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a regular grease gun fitting that is in a recessed locaton and I cannot get a grease gun on it. I looked for a small-head (small diameter) extension like they used to sell but no dice at NAPA. I did buy a small-head extension that you just press on the end of the fitting in a surface-to-surface way but grease goes everywhere.
I could also get by if I could find a regular -straight only---size small grease fitting that is longer than normal and then it would reach beyond the recessed hole it sits in. I didn't search yet in hopes someone here can offer the info. This not a foreign piece of junk but rather high quality American with this one particular oddity.
Does anyone know if a small-diamer lock-on grease gun extension is still available OR does anyone know if a longer than normal standard size SAE thread grease fitting is available?
Thanks in advance.
/ Need small diameter grease gun head OR longer fitting #2
Have you tried a needle tip on your grease gun. You can poke the end of the needle into the center of the zerk and usually get it to take grease.
Bill
/ Need small diameter grease gun head OR longer fitting #3
Bill
Bill, Great minds think alike ;)
Sixdogs, please don't double post. Check your post in Grease and Lubrication.
/ Need small diameter grease gun head OR longer fitting #4
I routinely use pipes to extend fittings out for easy access. Vibration may be an issue though, or a rotation problem.
/ Need small diameter grease gun head OR longer fitting #8
I have seen some grease guns with a coupler that is verry large and that might be your problem. Lincoln makes the smallest dia. coupler I have found .
Bill
/ Need small diameter grease gun head OR longer fitting #9
go to a John Deere dealer and ask for JD7813 it is a straight grease fitting about inch long with a 1/4-28 threads, it is used on the rear axle of a JD 6600 combine,
the spec, below says it made by Lincoln and the number is given, and the cost is about $1.55 at my dealer,
Specification
Weight 0.00 LBS 0.00 Kg
Fitting Angle STR
Effective Thread Length (Minimum) 0.200 IN
Shank Diameter 0.260 IN
Shank Length 0.810 IN
Overall Length 1.120 IN
Ball Check / Thread Type Code YES
Supplier Number - Stewart Lincoln Warner 1698
Number of Lincoln
Finish
Note
If that is not the size you need below is from there page on fittings and the numbers and the threads
not sure if one will not have to sign into the web site to access the page,
it is under product info and documents, after you put in a part number,
https://jdparts.deere.com/partsmkt/document/english/pmac/5741_fb_Grease_Fittings.htm
Threaded straight grease fittings
Description
Part no.
Grease fitting 1/8-in. PTF special extra short thread.
21/32-in. overall length.
JD7759
Grease fitting leakproof. 1/8-in. NPTF thread.
27/32-in. overall length.
JD5815
Grease fitting 1/8-in. NPTF thread (female).
1-in. overall length.
JD7794
Grease fitting 1/8-in. PTF special short thread.
1-1/4-in. overall length.
JD7771
1-3/4-in. overall length.
JD7782
Grease fitting 1/4-in.-28 taper thread 1.12-in. long
JD7813
Grease fitting 1/4-in.-28 UNF 2A thread. 15/32-in.
overall length.
JD7842
Grease fitting 1/4-in.-28 taper thread (SAE-LT).
17/32-in. overall length.
JD7797
Grease fitting 1/4-in.-28 taper thread (SAE-LT). 11/16-in.
JD7803
Grease fitting 1/4-in. PTF special extra short thread.
15/16-in. overall length.
JD7769
JD7819
Grease fitting 1/8-in. PTF special short thread. 2-5/8-in. long
JD7779
Bill
BHD--thanks for the effort and I'm checking it out. I can access JD parts so I can look.
Bill--There is a difference between the largest diameter grease gun head and what is now called the standard head but there used to be a very small diameter slip-on adapter that fit, now tht I remember, between the yokes of a u-joint when tilted and hard to access. I am going to call Lincoln today.
Since you are a car guy, this is for a street rod I just finished and the front king pin grease fittings are recessed just a bit and difficult to access. I am first a tractor guy but here is the car photo...it came out better than I expected. A small head adapter would have many tractor and equipment applications as well.
/ Need small diameter grease gun head OR longer fitting #11
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2022 Mac Trailer T/A Walking Floor Trailer (A61568)
2022 Mac Trailer...
2019 CAT 259D (A60462)
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
DEUTZ MARATHON...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
