JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,719
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
Every tractor "class" can operate tools, attachments and pto equipment appropriate for the class. There is a plethora of implements made for the tractor in the 18 hp/14 pto hp class. But a BX owner, even one whose tractor has the nifty ExraPower sticker,or a B owner is still not able to use or run the devices intended for a high powered L or M class or beyond. Each class and sub-class is also priced accordingly. Each class has its storage space requirements, fuel consumption appetite, weight, and maneuverability, cost of maintenance, and so forth. You pays your money and you takes your choice.
The question asked by the OP was simply why buy a BX1860. As you read this forum, on various threads, it seems one finds two kinds of BX owners. Those who are thrilled with their purchase because, for their needs, it meets or surpasses their expectations or the other kind of BX owner wishes he had bought or is now planning to buy a larger tractor. Either their needs have changed or they they misjudged their needs in their original purchase.
Soon, however, you also discover both of these kinds of tractor owners in every other class too. Even BX2660 owners. (Not sure this will apply to me but maybe it will)![]()
I believe you forgot us 3rd kind of BX owners. We keep buying different BX's, B's and L's till we find the right combination that works for us at our current job demands. I've bought 9 Kubotas in 6 years and 4 of them have been BX's. I started with a BX2200 and traded it for a B7800 and then added a BX1500 (decrease in Hp on BX) but added a B increased HP to make up for any shortage in HP. Traded the B7800 to a L3240 and traded the BX1500 to a BX2350. Traded the L3240 to a B3200 and traded the BX2350 to a BX2660. Odd that my fluctuations in BX's have ended up with a higher Hp BX and also my B's have increased in Hp and equaled the HP as the L but with 2000lbs less weight. And I'm the contrarian that bigger isn't always better. Quite obviously I never tried a BX18xx so that may be where I messed up.
