Front end loader Q's
/ Front end loader Q's #1
e.myers
Springhill, SC
Kubota L4400 4WD Hydrostat
If you knew the heaviest thing you'd be lifting with your FEL was a bucketful of Sand Clay, would you even consider adding ballast to the rear tires?
When would the wheelbase of the tractor become important for this type of weight?
If I could get the same loader size of a larger tractor on a smaller HP tractor (spec'd from factory), could I assume that for moving the clay I'm describing, the tractor would not have any more difficulty?
Where is being down on horsepower going to affect my front end loader work?
/ Front end loader Q's #2
No, but I certainly would have something heavy on the 3PH.
I am not exactly sure what your asking with the other questions?
/ Front end loader Q's #3
My farm is primarily a clay type soil and a full bucket can definitely get my unloaded rear tires light and squirrely. Especially if there is any moisture in the soil.
I have a Kioti DK45SE tractor with a 6 foot wide bucket.
/ Front end loader Q's #4
Most Front End Loaders (FEL) are made for a specific frame size and weight. Putting a larger size. For example the kubota L2400 and 3400 both take the same size LA463 FEL. When you move to the larger L4400 it takes the LA703. The are not interchangeable.
/ Front end loader Q's #5
Sand is pretty heavy . My loader tractor has loaded tires and wheel weights , makes for a much safer machine . I do not need a implement on the hitch for loader work , but a rear blade is usually on it also .
/ Front end loader Q's #6
As noted, not necessearily. But even with loaded rears you could find that more weight would help. Half of a 55 gallon drum filled with concrete and a linkage drawbar cast into it can really anchor the rear end to the ground. If you have FWD, and use it with a light rear end, you could experience premature wearout as it would be the prime mover of your load vs the rear providing the driving forces.
Always is a factor as the moment about the front or rear wheels would be increased or decreased with changes in wheelbase. The longer wheelbase would get by with less rear end weight, theoretically.
No, it could have a lot more difficulty due to lesser inherent weight and power.
Where is being down on horsepower going to affect my front end loader work?[/QUOTE]
It will impact virtually every aspect of loader work from entering the pile to transporting the loaded bucket. Horsepower X distance = work. Vary the variables results in more or less work, theoretically.
/ Front end loader Q's #7
You didn't specify whether the tractor is 2WD or 4WD. A loader with 2WD and unloaded tires is about useless. If the terrain is hilly, it's plain dangerous (most tractors only have brakes on the rear wheels and if there is not enough weight on the rear wheels, you have no brakes).
Even with 4wd, you would be putting all the traction load on your front drive system, which typically is not as strong as the rear drive system.
Loaded tires will also help you push into the dirt.
On my small loader (Kubota B21 TLB), I only notice the horsepower limitation when going up the steep driveway. It's slow. For normal loader operations, I don't run at full throttle. For the bigger tractor (Kubota M5040), loader operations are usually at low rpm, but it's a manual transmission.
Interesting stuff!
Could try without the loaded tires, but going to get them loaded anyway based on what I'm hearing. Will be rolling up and down some pretty steep jumps (not necessarily over), so it's pretty clear how the extra ballast could be beneficial.
Interesting on the half drum concrete idea. You think that would be heavier than a medium duty tiller (734 lbs).
Hadn't thought about the additional wear and tear on the front tires... probably the front end in general.
Starting to get a handle on how the HP relates to the material now.
Thanks everyone.
/ Front end loader Q's #9
Interesting stuff!
Thanks everyone.
Keep in mind that adding weight to the 3 point hitch will remove weight from the front axle and will reduce stress and wear in that area. the rears tire fluid loaded are highly recommended along with the rear weights on the 3 point hitch.
/ Front end loader Q's #10
You didn't specify whether the tractor is 2WD or 4WD. A loader with 2WD and unloaded tires is about useless. If the terrain is hilly, it's plain dangerous (most tractors only have brakes on the rear wheels and if there is not enough weight on the rear wheels, you have no brakes).Even with 4wd, you would be putting all the traction load on your front drive system, which typically is not as strong as the rear drive system. Loaded tires will also help you push into the dirt.
Interesting stuff!Could try without the loaded tires, but going to get them loaded anyway based on what I'm hearing. Will be rolling up and down some pretty steep jumps (not necessarily over),
Interesting on the half drum concrete idea. You think that would be heavier than a medium duty tiller (734 lbs).Starting to get a handle on how the HP relates to the material now.Thanks everyone.
It's just plain Dumb and Dangerous operatin a loader with out proper counter balance.
/ Front end loader Q's #11
I agree that it is not right to run a tractor that isn't ballasted right. It is just as important to make sure that it isn't over ballasted as well as under ballasted. You should look at your chores and the percentage of when and where before you add anything.
To over ballast you pay more everytime you move the tractor. You might find that for two or three extra bucket loads might make the extra ballast be a hinderence.
/ Front end loader Q's #12
Sorry I have to disagree with this some :( Adding even more weight that close to the rear will not take weight off the front. In order for the weight to lessen on the front the weight added to the back would have to stick out quite far from the pivot point{being back tires}. I'm not saying one should not have weight, they should of course. If the rear is weighted and the FEL is weighted the balance/pivot point then falls over the front wheels. Weighted tires are a great idea to help with traction and control. Even more important is learn and know the limitations of the machine.
/ Front end loader Q's #13
Adding weight via the three point hitch will definitely transfer weight off the front axle to the rear axle. It is, after all, a simple first class lever.
"the "balance/pivot point" falls over the front wheel"
I have no idea how you would get to that point. That would mean the tractor balances on the front axle.:confused:
/ Front end loader Q's #14
I must agree with Mace Canute, it is a simple lever and fulcrum. Regardless of how short the lever, putting weight on it will tend to pull up on the front. For a real life demo, just hook something heavy on the back and see how light the front end gets. Of course moving the load back futher from the axel give you more leverage, but any leverage is better than no leverage.
As for loading tires, why wouldnt you? It is relatively cheap, almost free if you live in a temperate climate and dont need antifreeze. It stabilizes your tractor, gives better traction, saves on tire wear since you have less wheel slippage and I find it actually gives a smoother ride on my tractor as it seems to give less rebound effect. THere is just enough air to cushion the blows, but not enough to give the basketball bounce effect. I cant believe that someone actually said that filled tires increased their fuel consumption. For any given load, you would more than make up for any HP needed to get the load moving by decreasing the slipping. I ran my tractor for about a year before filling the tires because I just never could find the time to do it. I can see appreciable wear on the rear tread from slippage in this short time. Inflation pressure is a bigger also. Lower your tire pressure till you see a slight buldge in the tire which in my tractor is about 10 psi. You can also check by wetting your tire and driving across concrete and check for full contact. You could have full contact and still be overinflated which will significantly increase tire wear in the center of your tread. Ideally the tires should wear evenly across the tread on the rears. The fronts will likely wear more on the outside due to turning.
/ Front end loader Q's #15
Its ok if you dont agree we all are allowed our opinions but I am speaking from experience and I have been in the situation where the tractor is balanced only on the front wheels (going steep with loader bucket full/heavy bucket) and let me tell you it was scary and I was so thankful that I had 4wd. The weight you add to the back is not proportionately removed from the front and that is why you have to add so to do much good in this respect. Tractors in the CUT and UT size are designed to handle the weight and stress on the rear axle. IMHO:)
/ Front end loader Q's #16
OP, lots of detailed info below... my .02 is:
must fill tires
must have weight on rear 3ph... in my case, I use box blade with numerous additional removable weights... thus can add/remove as needed to get right balance. I'm talking about 500 extra lbs plus the box blade. Such sincere rear weight DOES take some load off front axle... I DO understand that when front axle becomes the fulcrum (been there going down hill once) then ENTIRE weight of tractor, FEL and contents and rear implement is all on the front axle... best not to do that often.
must have toothbar to dig in clay...and this will increase your bucket carrying capacity, thus another need for rear weight
4wd next to mandatory for FEL work
must make sure your FEL hydraulic relief valve is within specs....not below...numerous TBN folks, myself included, have discovered that our valves were somewhat below factory specs, thus reducing FEL carrying capacity.
best to get the heavy duty FEL bucket... I have one. I've added chain hooks to my bucket with no need for reinforcing, and toothbar prevents bend in lower lip. Others with lighter buckets report need for reinforcing and bent lips.
you WILL find things heavier to lift than your FEL can do... so, best be set with rear weight and able to handle the max your relief valve can handle when the situation arises.
/ Front end loader Q's #17
I dont believe anyone said it was directly proportional just that it would take some weight off the front. Since any weight applied behind the back axle would act as a lever with the axles acting as the fulcrum it would naturally tend to raise the front end. I have an 850 # tandem disc that will illustrate that point very quickly as you can visually see the front end raise up when the disc is raised. Pop the clutch on it with the dics up and you can see a lot more raising. Point is that any weight placed back of the axles will take some weight off the front axle and the further away from the axle it is placed the more weight it will remove from the front. If you had a long enough lever, 5 lbs on the 3PH would pick the front end off the ground if your tractor hydraulics have the power. I think it was Atlas that said give me a fulcrum and a long enough lever and I can move the world.
Of course if you built a lever long enough to pick up the front with 5 pounds of weight, the lever itself would likely weigh more than the tractor would pick up. We have to maintain some semblence of balance between front/ rear weight ratios to achieve optimum lift without over stressing the tractor frame and axles.
/ Front end loader Q's #18
I think most missunderstood what I was suggesting. Take a few hundred lbs and add it to the back, right on the 3pt bar does the tractor{no FEL} front start comming off the ground{I would hope not}. Now add the FEL with the same amount of weight{few hundred lbs} This brings the weight back towards the center of the tractor or even closer to the front because of how the FEL sticks out. Very simple physics here. Your getting stuck on the idea of weight being the same AND at the same distance from the front and back axles. Once the weight changes or the distance then the balance {weight shifting} moves either towards the front or the rear depending on what is being done.
/ Front end loader Q's #19
This was aimed more towards just adding weight to the tires. Once again tractor with no FEL rear tires weighted no problem. Now add a FEL and then add a heavy load the weight balance shifts towards the front axle. So even though a tractor may not tip the balance will shift onto the front axle and because the FEL sticks out over the front axle this means it is trying to pick up the back end of the tractor.
Simply put take a tractor with no weights or weighted tires set it on a scale. Now add the FEL still seems allright now lift the FEL and start adding weight slowly the weight transfers towards the front axle Until the back starts to lift off the ground. Now start adding weight to the back tires. The back will come down but at the same time the front will also get heavier. Don't believe me that's fine, go to a truck scale and watch the boys move the axles around on the truck and trailer trying to average out the weight.
/ Front end loader Q's #20
I've also driven with the rear off the ground your're correct not much fun. I tried to explain myself better on the last post hope that makes more sense. sorry to be so confusing. The point I was trying to make was more about knowing a tractors limitations then weight. We could take a tractor and keep adding weight until everything just snapped. Just remember adding more weight does not lesson the overall weight of the machine and depending on placement of load weight etc... the weight does shift between 2 points the back axle or the front. I get a kick out of these guys that say I added weight to the back so it made my front lite. Of course once they start really loading up the FEL some how they still lose traction with the rear wheels. Wonder why??? Maybe because the balance is shifting onto the front wheels????
Gem Electric 6-Seater Cart (A61166)
Gem Electric...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
(4) Trail Finder S2 215/75R/17 Tires and Rims (A64047)
(4) Trail Finder...
30 Yard Dumper (A61166)
30 Yard Dumper...
