CAMPHOR LAUREL REMOVAL .
/ CAMPHOR LAUREL REMOVAL . #1
Eagleview
Orstraya , Ex convict stock , G'day .
Well , I know how much you guy's like pictures so here's some of today's dicing with death . These Camphor Laurels had to be removed for a property access road . They are way to big for my machine but I did it anyway . When you consider this excavator weighs 23 tonne/ton and is quite large , it's easy to see just how big these trees were . The vines I had to tear out of the trees before I could pull them out were unbelievable , at one point I had the front of the machine in mid air , just hanging on them . The things we do for money.....:rolleyes:
/ CAMPHOR LAUREL REMOVAL . #2
It's always amazing that no matter how big of a machine you have, it's never big enough!!
Great pics. Do you ever take them out by digging around the root ball and pushing them over?
Eddie
/ CAMPHOR LAUREL REMOVAL . #3
I think I might have been afraid of some of that falling and crushing me and the cab of the machine.
Yes Eddie , the next one I will be doing on Monday is twice as big , so it will be getting dug around and pushed over .
Bird , you are right I should have full cab protection on the machine for a job like this .
/ CAMPHOR LAUREL REMOVAL . #5
i am amazed that the lift power of that machine....does that attachment do anything to increase your leverage? or is it all the carrier?
/ CAMPHOR LAUREL REMOVAL . #6
Do they have tap roots..., or just surface..??
I've taken out a quite few with the ole' Kobelco 210... I'd cut all the roots I could, except the side I was pushing it towards. A little safety thing in my mind, in case I slipped off the trunk. Didn't want it crashing down on me.
Always thought it would be cool to have, and tried to talk the boss in to having a single shank root cutter/rock ripper about 2-3' long out of T-1 steel. Didn't happen, but could have used it a bunch..!!
With the quick-attach, it sure would have been sweet...
It seems we did find a ripper designed for rock in a catalog, which would have been great for when we were ripping shale for fill...!! But that's all we did... Find it, they wouldn't spring for one...
/ CAMPHOR LAUREL REMOVAL . #7
Getting them on the ground is the easy part. Making them disapear is when it turns into work. Do you burn them? Haul them off? What do you do with them and how do you do it?
Eddie
It was a strong machine to start with but Ive wound the pressures up a tad . Sometimes the reliefs crack under extreme loads and the boom will slowly lower . I just need to think ahead as to what I'm going to do with the tree and where I can place it before tackling it .
DJ54 , they are mainly a surface root tree depending on soil type . Most people have seen this photo but I'll put it in here for those who have not , it shows the typical root system they have . This is a more manageable size tree for this machine . I need a 30 tonner for the others , but don't want any more expensive garden ornaments .
Eddie , you are right , it is a mission to get rid of them . They are usually piled for burning or they are chipped , but I have to cart them away from this job . A local sugar mill is said to take them for boiler fuel . I will contact them tomorrow to see if they will pick them up .
This is how I am getting rid of the trees , 70 cubic metre/yard bins . Left bin for trash to the tip and the Right bin for logs to the Sugar Mill for "Green Energy" production . I don't know how I would manage without my "Talon" grapple with it's full length top clamp .
/ CAMPHOR LAUREL REMOVAL . #12
How does that work out price wise on your end? Right now, the best I can get is $10/ton for pulpwood and decent saw logs (oak, walnut, etc) aren't much better, around 0.15/bd.ft. Almost doesn't pay the cold beverage tab. :(
I told them I didn't want anything for them . The rubbish dump were going to charge me $50 a tonne/ton to dump them . So nearly 60 tonnes so far , only costing me transport has saved me a bunch .
It's all political fuzzy logic anyway , if you take into account the fuel used to fall,skid,and load the trees , then the vast amounts of fuel poured into a huge grinder to chip them and then the fuel burned to truck it to the mill which then burns it and sends the Carbon straight up the chimney into the atmosphere . It makes our pollies feel like they have justified their existence tho . I hate to tell them that the Earth has been warming since the last ice age 10,000 years ago and that Carbon is the building block of the universe .
What a mission , 11 , 70 cubic metre/yard bins of timber and trash from a one acre block of land . Snakes , Rats , Ticks and Spiders where a daily encounter . My Fox Terrier took care of the rats and the excavator bucket took care of the Snakes , Ive still got a lump on my neck from a Tick and I wont mention where a Spider bit me but I had to drop the strides to eradicate it .:eek:
/ CAMPHOR LAUREL REMOVAL . #15
Perhaps something like this would interest you. Select new products. RIPPER
MetKit Corp - Home Page
It is in Northern New South Wales , but only 100 kilometres from the Queensland border at Tweed Heads .
This is Jamie and Becky the new owners of the land and my Foxy "Chewy" looking on . I asked them to stand in front of one of the stumps for a photo while I held it with the excavator . (She will kill me if she finds out I posted this photo while she was in her house cleaning cloths .:D) The job took 8 days because I had to wait on the bins to be emptied and also the fact that the stumps had to be dug out and disposed of before I could form the new carriage way .
I made good money from the job and now I can't get away as all the neighbours have me doing jobs for them while the machines are there .
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
(4) Tractor Wheel Weights (A65640)
(4) Tractor Wheel...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2025 SDlanch SDLD25 (A64127)
2025 SDlanch...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
