Replacing a Clutch on a MONTANA 3840
   / Replacing a Clutch on a MONTANA 3840 #1
FIREFIGHTER6CO6
Virginia
I got a quote on replacing my clutch today for $1200, does this sound right to anyone?
   / Replacing a Clutch on a MONTANA 3840 #2
Sounds like a good price to me, because I am assuming that the tractor has to be split. My guess would be you're probably a couple hundred dollars in parts and the rest is labor.
As long as it is a reputable shop, I'd say it's money well spent (so long as that is what needs to be fixed with the tractor).
Good luck and take care.
   / Replacing a Clutch on a MONTANA 3840 #3
Sounds real good. They must be using a reman pressure plate? Make sure the flywheel is good or resurfaced.
   / Replacing a Clutch on a MONTANA 3840 #4
That's the price I got to replace it in my kubota; $700 for the clutch and up to 10 hours labor.
   / Replacing a Clutch on a MONTANA 3840 #5
UPS just delivered a rebuilt clutch (pressure plate, disc, throwout bearing) today for my 1951 Minneapolis Moline BF tractor that I'm restoring. Cost: $270. There's a $30 core refund on the pressure plate and disc if you send the old parts back to the supplier. This is a simple Rockford RM single disc clutch for a tractor with a 27 hp gas engine.
I assume that your 3840 has to be split to do the clutch job and my guess is that the clutch pack is more expensive than the one I just got.
So considering the labor involved, $1200 doesn't sound bad.
   / Replacing a Clutch on a MONTANA 3840 #6
Price is not bad. I assume you have a dual stage clutch. No sure if you want to tackle it or not but this can be a do it yourself project if you have a buddy to help and a free weekend.
Chris
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
