John Deere 4520 Cab - Which Backhoe
/ John Deere 4520 Cab - Which Backhoe #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am thinking I want a backhoe for my 4520 cab.
Which one fits it?
How much are they?
How are they to put on and take off?
I wonder if I should consider putting one on my 5525 instead.
Thanks,
Darin
/ John Deere 4520 Cab - Which Backhoe #2
For the price of one (8k or so...) I would consider a used mini-excavator first. This is a great time to but used construction machines. Plus they are far more efficient that the tractor mounted hoe.
A used backhoe is probably the route to go anyway, but who knows. Maybe I can find a nice used one.
D.
/ John Deere 4520 Cab - Which Backhoe #4
Given the size of your place I would consider a nice used JD310 or Cat 416-420 backhoe. This would enable you to do some serious digging while at the same time would provide you with a very good loader too.
I like the mini excavators too but they are much slower to move around in large open areas. If that isn't a problem for you then the mini excavators would be a cheaper solution.
Steve
/ John Deere 4520 Cab - Which Backhoe #5
Which one fits it?
How much are they?
Thanks,
Darin
I bought a new JD 485 BH for my 4320 a couple of mos ago for just under $8k.You'd pay several hundred less if you already have power beyond. I believe the 485 BH is the latest model made for the 4x20 series tractors.
Install/uninstall is very simple (no wrenches) -- just two pins and two hydraulic hoses. Have to remove the 3 PH lower arms to install BH and put the arms back on after removing BH in order to use 3 PH.
If you are going to use the BH a lot, I would look at the larger dedicated BH's as suggested above but you'll be spending a lot more money.
/ John Deere 4520 Cab - Which Backhoe #6
D,
I have been to your place and saw how you work and you would kill yourself hooking up and unhooking a hoe. I agree with he guys that a used mini-ex is your ticket.
cb
/ John Deere 4520 Cab - Which Backhoe #7
D,
cb
I wouldn't argue against a good mini excavator being better, but it will be quite a bit more money.
However, I will disagree with the install/uninstall of the 485 BH. I purchased the JD 485 BH a couple of mos ago for my 4320 and have had it on and off several times. No tools, no lifting, just use the 3 PH (upper arms) to lift into place and lock with two large pins and connect a couple of hoses. The lower 3 PH arms must be removed when installing the BH and then installed when using rear implements w/o BH. IMHO, it doesn't get much easier than that.
I'm not familiar with the older backhoes so maybe they are more labor intensive to install/uninstall.
/ John Deere 4520 Cab - Which Backhoe #8
Another important factor to consider is where you will be using this machine. For example, I own approx 300 acres comprised of 3 parcels all along a secondary road spanning about 1.5 miles. A track excavator just isn't ideal/practical for this situation. Besides the time factor moving the excavator, the undercarriage would wear and need frequent service. So, a TLB is more desirable in this situation unless you want to invest in transportation equipment.
/ John Deere 4520 Cab - Which Backhoe #9
I saw exactly what you need to buy on ebay this morning for your 4520 cab.
woods backhoe on ebay 2002 Woods BH9000 Backhoe Attachment 2 BUCKETS! - eBay (item 190336781979 end time Sep-28-09 11:35:50 PDT)
You need to call woods equipment and see if they have the custom frame mount for the bh9000 to fit your 4520 cab tractor. I would think they would have a kit.
I have a kubota 3240 cab with the woods backhoe and woods frame mount and can hook and unhook in less than 5 minutes.
Also, I would not want another piece of equipment (buying a backhoe/trac loader) to have to deal with storing it and servicing it and letting it set most of the year. I would rather have a attachment for the tractor plus it will cost much less.
/ John Deere 4520 Cab - Which Backhoe #10
Not trying to hijack this thread but I have a question on this matter. I found a JD 448 BH on our local Craigslist for $6000 and intend on looking at it. It has approximately 50 hours on it and seems to be in good shape. I have a JD 4120 I intend on putting it on. My questions are: Is this a good price? What will I have to do to my tractor to attach it? Is power beyond, just the hydraulic connections on the back (I have two there now). Is there anything I should look out for when looking at this BH?
/ John Deere 4520 Cab - Which Backhoe #11
I just bought a new 485 BH a couple of mos ago. If the 448 is anything like the 485 you will need the Power Beyond Kit and the attachment frame for the 4x20
tractor series. According to my local JD dealer the 448 was replaced with the 485 and the 448 is no longer available (new). I paid a little less than $8K for a new 485 BH, PB Kit, attachment frame, and installation labor. If it were me, I'd go the extra money for a new 485 BH.
/ John Deere 4520 Cab - Which Backhoe #12
I was thinking that was high. The seller said this BH was on a 4120, so would'nt the mounting plates already be there? Thanks.
/ John Deere 4520 Cab - Which Backhoe #13
I agree buy the newer model with install and warranty.
Steve
/ John Deere 4520 Cab - Which Backhoe #14
Definitely have answered that you need the newer model 485 BH - given that you've got a cab 4520.
But really haven't answered the question if that's the solution to the kind of work you have in mind...
Lot's of digging projects? Installing/replacing culverts - cleaning out drainage ditches - building new drainage ditches? Irrigation project/projects? = Excavator.
Or just a few stumps? New leach field for your septic system? Bury that old cow? = Backhoe.
Best of luck.
AKfish
2006 LeeBoy L8510R Low Deck Asphalt Crawler Paver (A66734)
2006 LeeBoy L8510R...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2012 Mercury 25HP Outboard Boat Motor. (A66738)
2012 Mercury 25HP...
