John Deere 316 smokes
/ John Deere 316 smokes #1
johndeere316
I have a John Deere 316 that i got for $200.00, this gentlemen that own it, had it in the middle of a field. I brought it home started it and the engine smokes, it has the orginial anegine in it, Onan im not sure how many hours but it started right up, the problem is that it smokes, i changed the oil put new oil from the dealer and it still smokes, there is oil in the exaust but im we cleaned it and still is burning oil.
Im kinda upset because i love this tractor i was even going to buy attachments tomorrow for it but now i have to wait.
Any ideas on why my engine smokes?? Could it be the rings? im not sure what the problem is thank all for your comments.
/ John Deere 316 smokes #2
$200 and it runs?!! It needs too much work, I'll give you $250 and take it off your hands.
Seriously, it could be many things but I would start with a compression test and cylinder leak down test and then you would know if you need rings. Hopefullly that is it!!
/ John Deere 316 smokes #3
I'd bet 100% it is the rings, but valve guides will also add to it as well.
These are pretty easy motors to rebuild.
The jugs hang right out there.
It probably had too light of engine oil in it in hot weather.
These motors need 20/50 in the heat of the day and make sure all venting for cooling is clean air flow and no oil/dirt build-up holding heat on the outside.
2023 JCB 3TS-8T TELESKID (A65053)
2023 JCB 3TS-8T...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
Bush Hog 3815 RR2 (A64911)
Bush Hog 3815 RR2...
2017 HINO 338 REFRIGERATED 26FT CDL REQUIRED BOX TRUCK (A69167)
2017 HINO 338...
285/75R24.5 Tire (A68134)
285/75R24.5 Tire...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
