Mahindra camshaft problems
/ Mahindra camshaft problems #1
Broken 4110
2006 Mahindra 4110 stopped running. Mechanic found bent push rods and valves. Jumped timing! Removed camshaft and found cam journals scored - bad news. No bearings on camshaft! Factory rep no help! Only 700 hours. No one seems to have a fix. Second 4110 owned - may be my last!
Any Suggestions?
/ Mahindra camshaft problems #2
Any Suggestions?
I talked to the owner of the engine machine shop that I have used through the years and he told me that a good machine shop may well be able to repair your block. He also told me that a lot of the compact tractor diesels don't have cam bearings, and he has worked on this problem before on other brands. I hope you have a good outcome.
I now plan to move engine block to machine shop and see if bearing can be installed. Thanks for the advice
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
Wooden Plant Holder (A64557)
Wooden Plant...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
