Looking at used 1850's - its Charlie's fault!
/ Looking at used 1850's - its Charlie's fault!
I had a similar experience on my 1445, when a wheel motor hose blew, rolling backward. If I would have been thinking and not in a panic mode, I could have lowered the bucket for some extra drag. Fortunately, a tree stopped my travel before I was about to go into a large stream.
I do see the need for a shotgun shell powered spike that would be shot into the ground with steel cable to stop the machine in a run-a way situation.
Another way would be to put a electric hyd shut off valve on some or all of the hyd motors, to put them into hyd lock.
ideally an emergency braking system should be automatic. If hyd fails, the unit stops. I wonder if the tender can be acquired separately and fiited to the 2445....wonder the same thing about the tilt seat...
/ Looking at used 1850's - its Charlie's fault! #42
ideally an emergency braking system should be automatic. If hyd fails, the unit stops. I wonder if the tender can be acquired separately and fitted to the 2445....wonder the same thing about the tilt seat...
I believe you can make your own system real easy, by using a manual hyd pump, an accumulator, and a check valve, and a release valve. Even without the manual pump, you could design it to charge up the accumulator during normal operation.
Your system does stop automatically doesn't it? Unless your model is older. Mine had a cogged disk which is used a parking brake.
mine has an electric brake but i don't have a lot of confidence in it....mostly i rely on lowered implements...conceptually i'm with you but, with no hyd experience other than repacking a couple of cylinders, i'll need adult supervision...
/ Looking at used 1850's - its Charlie's fault! #44
If any of us had adult supervision our computers would be locked off this site.
I have been entertained by your speculations about making your 2445 into a slope mower. I have a vague recollection that the phones used to be answered at PT mentioning the brake tender as if it were separately marketed. I have no doubt you'd be able to adapt it to your machine, and would like it. JJ's accumulator and other auto brake systems might also work. Then, with new frames, wheel motors and duals, tilt seat and a rough-cut deck, you will have succeeded in creating a slope mower only marginally less capable than an 1845 - and you can leave the backhoe on in case you have to clear some tough stuff out of the way to get to the grass.:eek:
Have you considered a used 1850??:D:D
glad you are so easily entertained.....absent a really great deal on a used 1850 mower, i'm becoming convinced that ghetto-ing my 2445 with smaller diameter dual wheels might be feasible...
now about the old PT 72" decks. do i understand you and sedge discovered they can accept either rough cut blades or finishing blades? would i need new spindles to accomodate hinged blades and stump jumpers? plan would be to pull the 72" behind and angle-boom a 48" deck out front...
funny thing is when i mentioned converting the 2445 to a slope mower, me wif was dissapointed...said she thought we should find a mower so we had two tractors!
/ Looking at used 1850's - its Charlie's fault! #47
This is what is on my 1445; a pressure line from the aux circuit pressurizes the brake circuit and when something like 600psi is reached, the brakes are released. The electric switch is a solenoid that dumps the pressure from the system.
The Eaton manual for their automatically braked motors mention that you should only apply the brakes when the motors aren't moving. (Can you say hydraulic hammer?) However, in an emergency, I'll take any port in a storm.
All the best,
Peter
/ Looking at used 1850's - its Charlie's fault! #49
hmmm...wet disk brakes...i hate to let too much of my stupidity show, but do these have (possibly worn) brake pads like a car? with elec switch thrown to activate solenoid and vacate pressure, thus allowing brakes to kick in, i still get some creep without implements down. i'll generally use blocks no matter what system, but would like more protection all around so i'm considering retrofitting tender or equiv...
let's see...JJ wants to shotgun a spike into the ground and cable yank a 4,000 lb runaway into submission...you mention accepting any port in a storm and propose slamming the hyd system...
i'm thinkin recycled storm anchor from a sailboat...ya, that's it...hyd hose breaks...crisis mode ensues, but not for the calm and collected...i rip off my custom dust mask, taking care to dislodge and set aside cigar...casually turn around and hurl a 40 plus pound anchor and chain into the weeds...turn back around and grab the cigar, averting potential further drama from launched cigar based brush fire...and brace as the PT rears back like a pit bull againt its choke chain...where is Carl when we need him with cameras rolling for his PT CD's...
Well, you could let er build up speed, riding down the hill to the end of a 50 ft drop off, and then hear your self mutter, Ooooooooh CRAP.
that would be scene one...scene two would be a couple of back woods mechanics trying to figure out how to put proper brakes on the @#$% thing...
/ Looking at used 1850's - its Charlie's fault! #51
now about the old PT 72" decks. do i understand you and sedge discovered they can accept either rough cut blades or finishing blades? would i need new spindles to accommodate hinged blades and stump jumpers? plan would be to pull the 72" behind and angle-boom a 48" deck out front...
Our rough-cut 72"mowers came with the stump jumpers and 8" or so blades swinging on a bolt. Sedgewood and I cut that length blades from high-lift finish mower blades (mine Gravely) and drilled them to replace the heavier essentially straight PT blades. PT actually sold a ring with four fixed blades to make the rough-cuts into finish mowers, but I dug one into the ground and threw a blade, as in out and fast, so I went back to the articulated ones. You'd have to ask Terry what the finish deck would need to accept the stump jumpers. I'll bet they bolt in.
I am afraid a 48" out front and a 72" in back would overload your PTO. As I wrote before, in heavy stuff going uphill, mine can bog all the way to stall, just with the 72"
To get more width, I tow a Kunz Acrease 50" rough-cut deck. Not elegant, but I get almost 10' when I'm mowing level enough stuff that the Acrease doesn't drift downhill. I have the sickle bar for sides of trails, from vertical to 5 feet out. I think it's safer than a rotary mower on a boom, but not as flexible.
PS: Your wife's right. Two tractors are better than one, even if one is the world's most capable and flexible PT.
/ Looking at used 1850's - its Charlie's fault! #52
Well, I've thought about that myself...
Somebody with more time and energy than I've got should be able to replace the lame parking brake slotted discs with actual brake rotors from a common small car or maybe a motorcycle. Then weld up some brackets for calipers and use a motorcycle master cylinder.
Sounds easy if you say it fast enough, huh?
/ Looking at used 1850's - its Charlie's fault! #53
If you are getting close to 30% of a used PT, I think it makes more sense to get the used PT. The second tractor will have residual value and can also fill in for the other tractor in a pinch. For all the modifications you are talking about, i would be tempted to build my own PT from scratch, making it longer, heavier, and with greater lift capacity.
Ken
thanks for clarifications...
if my configuration of mowers off the neab and out front works, but at times overloads the hyd pump, i conceivably could adapt by shutting down either 4' or 6' mowers according to conditions. In theory, with up front boom mower and side to side control, i could park at the base and work a hillside side to side and then move up a bit and continue the practise....
now if that was all mounted on a used 1850 acquired for a kind price...all the better.
/ Looking at used 1850's - its Charlie's fault! #56
FYI, Here's how the spindles in my 72" roughcut are built. It looks like PT took a simple 5 lug trailer hub and welded a stump jumper "bucket" on the stub end and called it a day. It works well except for the tapered lug bolts drawn into straight holes in the deck they use to mount it - it keeps loosening up from the limited contact area.
I'd wager Charlie is right that these assemblies would bolt right on a finish mower.
PT-1845 Rough cut mower
Sedgewood
Sedgewood
thx sedge. i remember seeing that along with your exceleent research and writeups on deck and blade improvements. I've been looking into used pt decks. asdie from blade configurations they all seem to be typical PT bulletproof construction. I'm thinking about a three or four foot rough cut deck on the front and finish mower on the back.
While our fields are tall in weeds, poke and locust saplings right now, we'll eventually get down to maintenance so perhaps finishing mower would be fine for the six foot pull behind...I don't recall if you ever just had finish blades on yours...any insights into how the finish mower handles high grass...how big is the difference between finish / rough cut mowers?
/ Looking at used 1850's - its Charlie's fault! #58
In my search for better blades to cut high grass I cut and drilled some high lift lawn mower blades to try. The issue in high grass seems to be the left spindle in the multi spindle setup getting overloaded with its neighbors clippings and leaving an uncut stripe. I've tried several blades and eventually came to the conclusion that the problem is inherent in the simple rear discharge deck design. So I gave up, took the rubber deflector off the rear discharge and just mow shorter grass :) Except when I don't :-(
There's a discussion about this problem on here somewhere in a thread back-in-the-day not long after Charlie's great early posts convinced me I HAD to get me an 1845 (it's Charlie's fault!).
Sedgewood
/ Looking at used 1850's - its Charlie's fault! #59
Have you looked at/thought of using a swisher style mower behind the PT? something like this perhaps: Swisher Mower & Machine Co.: T-66 Trailmower
Aaron Z
/ Looking at used 1850's - its Charlie's fault! #60
Sedgewood
I still have the rubber deflector on. The high-lift blades do a smoother job than the original, and I seldom have a stripe as long as I keep the back of the deck adjusted an inch higher than the front. When it gets a foot high, or so and thick (particularly the wire grass stuff the horses won't touch), some stripe is inevitable.
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Clark C500-YS80 Forklift (A61166)
Clark C500-YS80...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
Kuhn FC400RG (A60462)
