GT2542 pto will not shut off
   / GT2542 pto will not shut off #1
Gorrell75
Kansas
cub cadet GT2542
I have a cub cadet gt 2542. When I start the tractor the blades start. PTO will not shut off. I have tried reverse shut off and still the pto is engaged. I unplugged the wires going to the clutch and still the same.
   / GT2542 pto will not shut off #2
sounds like bearing is bad take off clutch and have bearings replaced.
   / GT2542 pto will not shut off #3
I think you'll have a hard time finding bearings for your clutch and will have to buy a new one. The going rate for a new one is from $275-$300.
   / GT2542 pto will not shut off #4
What is so special about those bearings. I have rebuilt at least six older gen electric clutches..I have a 2542 so it might give me a start on a fix should mine puke..
   / GT2542 pto will not shut off #5
The problem with finding bearings is they are made special for Warner with metric outside diameter and inch inside diameter.
   / GT2542 pto will not shut off #6
I have a lathe and mill. Can take care of that problem. Never ran into that in my short 66 yrs. Proprietary crapola...
this should be under warranty?
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
KJ 7'x20' Metal Farm Driveway Gate (A53316)
KJ 7'x20' Metal...
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
40' High Cube-Multi Door Container (A53316)
40' High...
