mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,369
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Surging, pulsing and chatter with LA463 loader on a Kubota L3400HST.
This problem just recently developed.
I believe fluid levels are where they are supposed to be. I'm not sure where to check fluid level on the L3400HST This is my neighbor痴 tractor. I am a mechanical engineer and was asked to help.
When curling back or lifting the bucket, loaded or not, the loader valve and loader movement surges, pulses and chatters.
The loader will lift a few inches smoothly, then pulse and chatter like the pump is suction starved, then lift normally a few more inches, then chatter.
This occurs at any cylinder position. I can feel and hear the loader valve pulse.
When lowering the loader arms or dumping the bucket, the hydraulic flow appears normal. Then the loader is fully curled or arms lifted to relief, the relief valve does not chatter and appears to function normally.
Any help is appreciated.
