Paint
   / Paint #1
Bob Ha
DFW, TX
NH TN75, Kubota M9960, Kubota M7040, NH T4.85
I have a fender that needs some touchup on a 2002 TN75 and found some cans of spray paint online ... Ford Blue paint. Is Ford Blue and New Holland Blue the same? I was thinking Ford Blue paint was darker but not sure. Thanks
   / Paint #2
hit a cnh dealer they have paint at the counter.. also.. tsc has valspar paints in oem tractor colors..
soundguy
   / Paint
soundguy
tsc has Ford Blue... is that the same as New Holland Blue? thanks
   / Paint #4
Cnh has different "shades" or codes of paint for their tractors; the blue color became darker in early 2000's. You will need to know what color blue is on your unit.
   / Paint #5
ditto that.
soundguy
   / Paint #6
The Ford Blue looks greenish if used on the NH Blue. Found out the hard way on my TZ25. :(
   / Paint #7
Best match, exact match for me- I bought a gallon of paint from Dealer--CNH quality is excellent I used a brush to apply and the results were excellent dries fast..
looks like it was sprayed no brush marks.
I painted my land pride FDR 1672 --wow the blue makes a difference.
   / Paint #8
Krylon True Blue is practically a dead ringer for NH blue.
   / Paint
Called NH dealer today to see if they had any in stock and all I could get was we have plenty of paint. I asked about the change over in 2000 and got "we have plenty of paint". Either I have to buy ever color they have or cross my fingers. I never have good luck so maybe I should just purchase ever shade. Thanks for all the info!
   / Paint #10
Bob,
Your owners manual has the correct CNH paint part number for your tractor under I believe the maintence section.
If you do not have a owners manual and because your dealer sounds lazy call you next closest dealer and have them look it up on their computer- I bet they will be more than happy to help you out.
You can also go online to messicks.com and under the NH agriculture section under "parts" type in your tractor model number and under the subsection section "paint/decals" it will give the CNH part number for the exact blue you need in spray can, quarts or gallons.
2017 John Deere 5090GN (A53317)
2017 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Mini Margaritaville Truck (A55853)
Mini...
