Source for plastic barrel bung plug?
/ Source for plastic barrel bung plug? #1
Travelover
Elite Member
Washington
B7100
I loaned out my plastic 55 gallon barrel and of course it came back missing a bung plug (the fine threaded one).
Does anyone have a good suggestion for a source to get another one?
Thanks.
/ Source for plastic barrel bung plug? #2
The fine threaded one is 2" npt pipe thread so any pipe plug will fit.
mcmaster carr will have them if you want a new plastic one
tom
/ Source for plastic barrel bung plug? #5
The odd one is a Buttress thread. BTW, if all else fails on a local search, PM me and I'll send you one of each. I think I can spare them.
Jay
Jay
Thanks for the generous offer. I'm going to super tighten the coarse threaded ones so they don't get used (and lost). I did find a plastic PVC plug at the big box store for 88 cents that works perfectly. The trick was knowing that it was standard pipe thread and what size.
/ Source for plastic barrel bung plug? #7
Project 2
Project 1
In my search of drums to build these 2 projects I must have wound up with about 15 extra drums that I didn't need.
I sold the extra drums and kept the bung plugs if the person buying the drum wasn't going to use them for something like what I built .
As a result I have a few extra plugs for my system in case I need one.
/ Source for plastic barrel bung plug? #8
Project 2
Project 1
that helps the OP How ? . Around here I can get both bungs for 5 bucks for the pair & they come with a free plastic drum. 4 bucks if I buy a dozen drums :rolleyes: . Bob
/ Source for plastic barrel bung plug? #10
Project 2
Project 1
Hey Lb, i was thumbing through your pics and saw outer end picture, you know they make fittings like what you welded up? Check out threaded tank fitting at mcmastercarr
/ Source for plastic barrel bung plug? #11
Thanks for the Info! I searched every where I could think of and couldn't find anything like this around here when I built these 2 fuel storage set ups.
so I had a couple of these welded up
/ Source for plastic barrel bung plug? #12
I need a coarse thread plug for my barrel. Did the big box store have both or just the fine thread? If both, which store?
Thanks for the help...
Just the fine thread. I've seen replacement bungs on the internet but with shipping - not cheap.
/ Source for plastic barrel bung plug? #14
2*that helps the OP How ?
1*Around here I can get both bungs for 5 bucks for the pair & they come with a free plastic drum. 4 bucks if I buy a dozen drums :rolleyes: . Bob
2*It helps the op if someone in his area just might have done what I did.
It would also help him if I were to send him a plug would it not?
Careful you don't bite the hand that feeds him.:D
1*May be true in your area but unfortunately it taint so in mine and the OPs areas.
Drums are 15 to 20 dollars a piece when and if you can find them in these parts.
/ Source for plastic barrel bung plug? #15
Point is LB . The OP was allready offered a plug & declined , as He had allready solved his problem before you posted your pics . Plus You mentioned you had several spares in case YOU need them , I didn,t see an offer to send him any . But then again I read all the posts, not just the ones I want. :D
I also noticed You spoke for the OP that the Barrels were high priced in his area as well as in your area, I dont recall Him saying that. But I recon it could be. Luckilly I have a local Craigslist site I can get mine from . :eek:
At any rate it seems his Problems solved & thats the main purpose for this forum . I recon I just get sick of seeing your same ole pics posted over & over & over again. Must just be me . :rolleyes: . Bob
................... I also noticed You spoke for the OP that the Barrels were high priced in his area as well as in your area, I dont recall Him saying that. But I recon it could be. Luckilly I have a local Craigslist site I can get mine from . :eek:..............
These barrels seem to go for about 10 to 15 dollars on Craigslist, locally. I didn't want to buy a whole 'nuther barrel just to get a bung plug. I have too much clutter now - wife would kill me . :eek:
Thanks again for all the help.
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2018 CASE 650M LGP CRAWLER DOZER (A65056)
2018 CASE 650M LGP...
2021 Forest River Salem FSX 280RTX 30ft Toy Hauler T/A Travel Trailer (A66738)
2021 Forest River...
2012 PETERBILT 348 (A67714)
2012 PETERBILT 348...
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
