Lienbach 7300 and B7500
/ Lienbach 7300 and B7500 #1
theboman
Grayson, KY
Kubota B7500 HST
Can you use a Lienback 7300 on a Kubota B7500? I found a pretty good deal.... If the CEO agrees.
/ Lienbach 7300 and B7500 #2
Good Mornin Bo,
IMO the Leinbach is a little too big for the B7500. I have the 7300 on my Massey Ferguson 1040 and its about right for that tractor. My Massey is considerably larger than the B7500. I believe the B7500 is about 1400 lbs ccording to Tractor Data, as opposed to the 1040 which is about 3800 lbs and larger physically also...
I would recomend the smaller 7200...
Here is a pic of mine just finishing some post hole work ! ;)
/ Lienbach 7300 and B7500 #3
I used a Lienback 7200 behind my B7100 (16HP/12HP PTO, and slightly lighter than your B7500) just fine. The 7300 is pretty much the same unit, as far as I know. You'll be fine with the B7500.
/ Lienbach 7300 and B7500 #4
Good Afternoon Bo,
As Jay states in the previous post, he used the 7200 on his tractor and it worked out, I cant argue with that !
I did take a look on Leinbachs' site and the 7200 JR sounds like it would be a perfect fit, but that should be confirmed by someone at the factory or by a dealer.
Here is the info on the 7200 JR, L-7200 Jr.
If the seller of the 7300 is closeby, possibly you could try it out ! If not I would call the factory or a dealer and find out for sure, before purchasing ! ;)
The seller tried to let me take it the other day...won't fit in the borrowed mini-van anyway (darn truck, it's 9 weeks and counting in the Ford garage).
I'll check with them after Labor Day (this Monday) and go from there.
/ Lienbach 7300 and B7500 #6
I also agree that the 7300 will be a little too large for your tractor. PTO wise, you will be fine with either one since very little HP is needed to run the PHD. Where I think you will run into a problem is getting enough lift to keep the auger tip from dragging the ground during transport.
2013 KUBOTA SVL 90-2 SKID STEER (A65056)
2013 KUBOTA SVL...
2000 CATERPILLAR 322BL EXCAVATOR (A65056)
2000 CATERPILLAR...
PALLET OF HEAVYEQUIPMENT PUMP PARTS (A68842)
PALLET OF...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2002 SUPERLINE DO20T242LP T/A 24FT TRAILER (A66091)
2002 SUPERLINE...
