Forks Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used?
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #11
Be sure to add in shipping - TSC has a similar one for $400, w free ship to store.
If I buy the northern tool one they want $105 for shipping.
I tried 3 times to put the link in but it broke each time.
/edit - did you even try the search feature here?
There's load of info.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #12
Willl,
I knew there was some goodness to you. :) :) :)
This one actually has my interest for $279
MissouriThunder
Remember that those are of a fixed width so make sure you check that width versus your application. I've found that pallets come in a variety of sizes and need a variety of fork widths so if you are getting alot of different deliveries, fixed width may not work. Just pointing out the obvious.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #13
I might be wrong but I don think your tractor is going to lift a ton on the three point hitch either.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #14
Ya I would ask if I could material delivered on 1/2 ton pallets. Might cost more, but at least you're not worried about breaking something when handling them. Besides the pallets come in hand for all sorts of things.
Wedge
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #15
from the Deere page:
3-Point Hitch
Type Category 1
Lift Capacity (24-in. behind link arms), lb. (kg) 2200 (999)
Lift Capacity @ lift link ends, lb. (kg) 2530 (1149)
So pretty close.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #16
Tritonman,
I'm not asking my baby bota to lift a ton. Just love the idea of moving pallets with ease. I could also 3-pt fork a pallet and use it as a carry-all for moving stuff around the yard or even down the road.
scuvnut,
I checked the specs on the pallet fork that willl posted and it says there's 25" between the forks. That's perfect for just about all kinds of pallets.
newbury,
I didn't think about the extra $105 for shipping. Why can't my local Orchlands or tractor supply store stock these bad boys ?
MissouriThunder
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #18
I wonder if 3 pt forks would lift high enough to grab a pallet off my equipment trailer? that sure would make unloading wood pellets easy.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #19
Google Agri Supply. If you have one in your area they are 149.95. Don't know how much to have them shipped. They have very good service and equipment.
Eddie
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #20
newbury,
MissouriThunder
I told you - TSC does ship to store. And the OP did ask for a 1 ton lisft.
WayneB - the FEL isn't strong enough for the OP.
COOLTECH 34288 (A55745)
COOLTECH 34288...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
