Is this thing worth the effort?
/ Is this thing worth the effort? #1
whitedogone
Gold Member
Central Illinois
JD 4120
My buddy gave me this canopy that he used to have on a yanmar. I was thinging about fixing it up and useing it on my JD 4120. What do ya think? It is going to need the "legs" of the mount remade because the ones on there won't work the wider u bolts required on the JD Rops. It's also going to need some fiberglass repair. Also, the gelcoat is cracked in a handful of places. I did pick up a fiberglass repair kit...but I'm having second thoughts about spenting the time on it. BTW, it's a Tractop....anybody hear of them?
/ Is this thing worth the effort? #2
It certainly looks do-able to me. More "time-and-effort" than money should make you a very nice top.
BUT,.....naturally,...it all depends entirely on what the job is worth to YOU? I know some who would scrap it and buy something all shiny and new because they have the money.
I know some fellas that would look at it like the opportunity of a lifetime,..and when they were done with it,..man it would be beautiful. Rebuilt to fit their tractor, patched, sanded, polished and painted, with working lights all wired up and even a dashboard hanging from the ceiling with switches and indicator lights and yes, maybe even a radio and a cooling fan up there too.
BUT,...ah,..yes,... depends on what it's all worth to "YOU" !!
Best wishes to you, ..no matter which way you go!
CHEERS!
. . tug
/ Is this thing worth the effort? #4
I would say go for it. there is nothing more pleasing then something you did yourself. zman
/ Is this thing worth the effort? #5
If it was me, and I wish it was, I'd repair it, modify it and install it.
Eddie
Well, I guess I like a chalenge. I ground the gelcoat off the one large cracked area and patched it with the repair kit. I've got a few smaller spots to do that on as well. What do you do where the gelcoat is cracked? Also, I will be painting it deere green and was wondering if I should do the underside green as well. Does anybody know where I can get some of the welting (I think that's what it's called) to put around the lip at the bottom.
Well, just to update. I got the fiberglassing done and primed the fiberglass. I had to mod the brackets because the u bolts on my ROPS are wider. I mig welded some pieces on the sides of the orginal brackets and filled in the old holes while I was at it.
/ Is this thing worth the effort? #8
I'm glad to see you tackle it. Thats what I would have done also. Like I always say........ 'If its free, its for me!'
/ Is this thing worth the effort? #9
Looking forward to seeing it hanging and making a shadow. (and keeping the rain off also)
David from jax
/ Is this thing worth the effort? #10
I would consider coating the underside with something like a spray on undercoat, usually this can be bought in DIY spray cans at auto parts stores, and yes... wallyworld too.
That type of undercoating would help deaden the sound that will be created when the canopy vibrates, and the engine will make it vibrate some.
You should be able get the trim material from most reupholstery shops.
Thanks for the undercoating tip. I found some welting local. EXPENSIVE! I might have to keep searching as I need 16'. I beleive it's called windlace at some places.
/ Is this thing worth the effort? #12
it may be possible to split a rubber hose and slide it over, do this on my loader
/ Is this thing worth the effort? #13
You may also try a junk yard. I'd think you could find something wrapped around the inside of a door on a compact car or some such. I doubt it would cost you much.
I guess it doesn't REALLY need anything at all. I'm not sure it ever had anything on there. I was just trying to make it nice and clean.
/ Is this thing worth the effort? #17
JC Whitney has the moulding your looking for and I belive in different color's also.If I remember not to expensive.might really set yours apart from the rest of the crowd.
/ Is this thing worth the effort? #19
I hate to have to be the one to tell you this, but now that you've gone and put a fancy new lid on your tractor, you're going to have to wash and paint the rest of it.
/ Is this thing worth the effort? #20
Now, that turned out really well! Congradulations...:)
Mike
