Gravely L8 not starting
/ Gravely L8 not starting #1
2manyrocks
Super Member
I bought an old Gravely L8 earlier this year that was starting on the first or second pull until I put it in the barn about 3 months ago. Now it's not starting, and I'm wondering if the magneto assembly has been affected by moisture while sitting in the barn. It didn't start on starting fluid sprayed directly into the carb, either.
Although it would start pretty easily before I put it up, it cut out on me a couple of times when I tried to use it to till the garden. It had been running pretty hard for several minutes when it cut out.
Any guesses where to start trying to get it running right?
/ Gravely L8 not starting #2
Hi! First Remove spark plug and with spark plug wire near 3/16 in. to ground. spark would jump when starting. If not clean Remove carbon and polish contact of breaker point ( I use a small fine file) then adjust to .015 in. at TDC Piston.
Check wire end contact for corrosion. Good Luck ! Oldmech
Spark plug was dead. I replaced it with a new one, but didn't check the timing. It fired up and ran well for 30-45 minutes and then died like it wasn't getting fuel, and the engine was very, very hot. I used it to till up the garden and ran it hard during this time.
This engine has the slanted spark plug in the cylinder head. Is there a simple method of checking TDC without pulling the cylinder head?
Here is a picture after tilling today.
/ Gravely L8 not starting #6
Can't tell from your picture but it looks like there are no shrouds on the cylinder. That could cause your engine to run hot. Early models didn't have them and some people have been known to remove them. The engine can then run hot and have the exhaust valve stick. Does it crank back up when cool? Check your screen in the tank or the glass bowl filter and see if you have good flow to the carb. Check and make sure your cap vent is clear. If all that checks out, then your carb needs cleaning.
The way it died this time, I thought it was out of gas, but there's plenty of gas in the tank. It also fired right back up after it cooled off.
There is a shroud on the back of the engine where the fan is located but there is no shroud on the front of it. Looks like there are some mounting holes where a shroud would have attached?
From what I can tell, this is a 1964 model.
I will look silly here and answer my own post. The side air deflectors are missing, but just bought a new pair for $13 something each.
The paper air filter is dirty, but the local dealer says the paper air filter is no longer available. Any ideas or substitutes for it? I've got a couple of older machines with the oil bath filter, but I hate to rob one machine for another....
/ Gravely L8 not starting #9
You can convert it over to the later model filter that mounts on the side. Side mount ones use a standard Kohler air filter and pre-cleaner. Or check e-bay for a used oil bath filter. Those are my prefered type as they pull dirt, bugs, and moisture out of the air flow. The Kohlers are a distant second place due to being outside the hood where they can get wet.
I found a source for the paper air filter, but its about $20 including shipping.
Long term, the oil bath filter sounds more like the one to get.
Dealer also wanted $70 for points and condensor. Told him I'd look elsewhere. Looks to be about $30 elsewhere.
I was told by another guy yesterday that if you let a Gravely sit, the exhaust valve tends to stick. I've got an L1 that came not running from an equipment auction, and I'm wondering if that is what might be wrong with it as the engine is not easy to turn?
/ Gravely L8 not starting #11
Hi! For L8 I replace air filter for a JD 317 air filter Same dia. but 2in. more high I weld one extension on center bolt.
I remember my L8 start near everytime at first try. But after running in hot wheather. If I stop engine for 5-10 min. Impossible to restart. I think because Gravely engine run very hot( Bad cooling system) This product Vapor lock in the carburator and bad mixture. Twinty min. later it start first time. May be a thick intake manifold gasket could correct this problem. Check belt tension and bearings on fan system. We must think the Gravely engine was design SIXTY years ago. Good Luck ! Oldmech
/ Gravely L8 not starting #12
Actually, you can add another 12 years to the design age. The first Ls came out in 1937. Prior to that there were hex axle models that dated back to 1935 and look alot like an L. I have a 66 year old one that runs and a 69 year old one that will run again one day.
As for the heat problem, the new and improved gasoline with ethanol is even worse. Opened up the gas cap on a Gravely Kohler powered Pro 8 to find the gasoline bubbling from the fuel line to the engine. :(
FlaDon, could I ask how you acquired your knowledge of Gravely's? Not just anybody would have known to ask if I had missing air deflectors.
I had heard of Gravelys, but didn't know much of anything about them. I bought this L8 based on Gravely reputation and wanting to learn more, but have to say there's a whole lot I don't know.
/ Gravely L8 not starting #14
I have owned or operated Gravelys for over 35 years, own a collection of Ls and Cs ( and its growing :eek: ), and help out at a Gravely dealership. Also a member of the Gravely Tractor Club of America.
Left home northbound this trip with 3 Ls/Cs in the trailer. By the time I was finished, I had put 9 of them into storage. I have to keep a speadsheet just to keep up with the 2-wheelers that are pre-1976.
This L8 is my only experience with the original Gravely engine, and I haven't run it much at all. I have had more experience running a 566 with a 12 horse Kohler-it doesn't have the balance of the original L8 in my opinion. I wanted to get this L8 in running condition really to get an understanding of what the original Gravely was like and not so much to really use it. But I have a couple of others L's sitting that might run or might not --I haven't figured them out yet. I was curious what your thoughts might be on the question of repowering older Ls with Hondas versus rebuilding the Gravely engine? I kind of wish there was some cheap bolt on solution instead of having to rebuild an engine.
/ Gravely L8 not starting #16
With the Comm 10A/Comm 12 and later, the engine swap isn't bad. With an L or C, you run into the same problem as was found in the Comm 10. The gearing was too fast with the single gear on the engine. Change out the rear planetary set to solve that. Gravely didn't stick with just the Kohlers so there were Robin, B&S, and Wisconsin engines on them depending on models and timeframe and whether they had been changed. Now the Honda seems to be the best bang for the buck. It also sheds some weight that the old CI Kohlers had bringing it nearer to the Gravely engines weight. Unless you have a wartime one with the CI crankcase. That one gets you close to Kohler weight. Cost of a Honda is about the same as just the cylinder new from Gravely. That's what hurts.
Adams 16T Tender Body (A61307)
Adams 16T Tender...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
1995 Kawasaki Bayou 300 4x2 ATV (A60352)
1995 Kawasaki...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
