LD1
Epic Contributor
The Kubota L3400 only has a lift capacity of 1,142lbs at the pins. The John Deere 3120 with 300CX loader is rated at 1,598lbs. The Bobcat CT335 is rated at 1,650lbs at the pins and 1,300lbs 500mm (19.68 inches) in front of the pins. If you need to lift pallets like that the CT440 is better rated for that at 2,600lbs at the pins and 2,050lbs 500mm in front.
To keep it fair the l3400 isn't really a good comparison as it is a size class smaller than the tractors you mentioned.
The L3400 falls into the class with the CK kioti's and the JD 3032 while the CT335 is in a class with the JD 3x20, DK kioti's, and the Grand L kubotas. I have compiled some breif loader specs for comparison
All lift weight are @ the pins
small class 30HP
CT235...........1605
CK35.............1155
JD3032..........1186
L3400............1142
Large class 30HP
CT335...........1650
DK35.............1412
JD3x20...........1598
L3540............1792
As you can see there isn't much difference when you stay in the same class of tractors. I will piont out however that the specs on the CT235 almost seem too go to be true. I don't know if it is a typo but lift specs only 45lbs below the CT335??? This is the same tractor that kioti only puts a 1155lbs capacity loader on. I wonder why????
