Post driver return line
/ Post driver return line #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
My post driver has a 3/4" return line. My sump filler hole is just over 1". I put a barbed mender in the end of the hose hoping the other end would be long enough to stay in the filler hole. I should also add that there is no good way to tie the hose down in the hole. I can steady the hose but applying good straight downward force is difficult due to the location. I got through about 10 pounds and the hose came out of the hole. I noticed at the hardware store they had black rubber heater hose 3/4" ID 1" OD. I think a piece of that would fit great. There is no pressure issues but I wonder about heat and oil compatibility. Any thoughts? Any other suggestions how to get something to stick down the hole a couple inches? The hole is not threaded.
/ Post driver return line #2
Why not use regular hyd hose which has a pipe thread on it and put a 90 degree fitting and a 3/4 in by 6 in copper extension.
Thanks JJ. Sometimes I just need you to hit me up side the head with a 2x4. I was at the hardware store looking at fittings to put on the 3/4" hose that would stick in the hole and I also looked at the 3/4" copper I had at home wondering if I could stick that in the hose. Some how those two thoughts just wouldn't come together. I will check at Lowe's tonight to see what fittings I can dig up.
/ Post driver return line #4
The Filler hole on my Kubota has a 1" threaded fitting so I just got a 3/4 X1 reducer in galv steel to put on the end of the hydraulic and then got two short 1" x 3" pipe nipples and a coupling (because the hydraulic line wouldn't swivel) and connected it direct to my filler hole for the post driver. Worked flawlessly.
The only thing at Lowes that had a hose barb that would fit a 3/4" hose was a 1" PEX fitting. I ended up with a hose barb on one end and a solder fitting on the other. Then I got a 1"-3/4" copper reducer. I had copper pipe at home. I put it all together with the 3/4" pipe being just a little longer than the dipstick. So the tube fits about 6" into the hole and the reducer some what seals the opening. I will be trying it out tonight or tomorrow depending on the rain. Just to note PEX is slightly under sized so 1" PEX hose barb fits a normal 3/4" hose.
/ Post driver return line #6
Eric,
Is that a place that water can get in. Seal it up real good.
Yes it is a real good place for water. The tractor gets parked in the barn so as long as I am not using it in the rain I should be good.
/ Post driver return line #8
Can you plumb a tee in to the drain plug put plug on the tee an run the other port back up to the back of the tractor and put a QD on it that will keep it sealed.
tom
/ Post driver return line #9
Be careful that something dosn't come apart and fall in there and the pipe is short enough so it won't get caught in the transmission.
I was out pounding posts this past weekend. The new return line works great. Thanks for the help.
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
Aluminum Bell (A65583)
2010 CHEVROLET SILVERADO 1500 (A65643)
2010 CHEVROLET...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
