How does a 4x6 Gator do at snow plowing?
   / How does a 4x6 Gator do at snow plowing? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
So, I ran across a '02 Gator 4x6 locally, it has 215 hrs, a gas engine and it has a blade on the front. Has anyone run one of these pushing snow? We are sort of looking for a new "utility vehicle" to replace the 2x4 honda knockoff 4wheeler that we currently have (which has a hard time getting out of its own way) and being able to plow snow with it would be a big plus.
So, two questions:
1. How will it do pushing snow?
2. Is it worth $5k (assuming that it is ready to go and in nice shape)?
Thanks
Aaron Z
   / How does a 4x6 Gator do at snow plowing? #2
First off, I know pretty much nothing about 4wheelers - bear that in mind.
That said, weight and traction mean a lot pushing snow. I doubt those things weigh much, and imagine you'd have to take light cuts and plow with storms - ie 12 inches on the drive would probably stop it. FWIW
   / How does a 4x6 Gator do at snow plowing? #3
Aaron Z
Good gosh...it's barely broke in (mine has around 1400 hrs) and that's a good price unless it's been trashed. I don't have snow down here but mine is great in mud. I wish I had it when I lived in NJ.....I have no doubt it would push snow, but I would put some extra weight in the back when doing it.
   / How does a 4x6 Gator do at snow plowing? #4
I contemplated using my Gator to plow snow, up until about the time I got the 3320. I have no doubts that it would do well plowing snow, especially with all the rear traction you can get from a 6x4. The biggest issue is weight. The 4x2 and 6x4 Gators by nature are supposed to float over the soup, not sink in it. They do this because of their wide high flotation tires, their wide(width)/short(height) build, and their low weight. I believe the 6x4's will hold over 1k lbs of weight in the bed. I loaded up the bed with a layer of cinder blocks and that worked very well for traction in the snow.
At 215 hrs that thing is barely broken in. In comparison, mine is an 04 and I just turned 100 hrs last fall and currently have 102 on it. A neighbor just bought a brand new 6x4 Gator and does nothing to take care of it's appearance. At 5 years old, mine already looks years better. If I ever sold mine I would look for at least 6 - 6.5k, as it isn't just a stripped model either. Check to see what other features this Gator has, like does it have an electric dumping bed?, windshield?, bed liner?...accessories will add to the value.
   / How does a 4x6 Gator do at snow plowing? #5
I have a 6x4 diesel now for years, it's good for many things but snowplow NO!!!
The miniscule ground clearance combined with flat bottom makes it constantly high center. It does not go outside over 3" of snow on the ground... much disappointment to nieces & nephews.
6x4 does not turn sharp either causing plow users to remove one set of 4x4 drive tires. A newer 4 wheel UTV or ATV is much better suited to pushing snow.
You can always sell the blade & buy a skidloader or rear blower for the 3pt tractor hitch.
   / How does a 4x6 Gator do at snow plowing? #6
3" of snow? You must be kidding. If it won't go through 3 inches of snow than you have bigger issues. I've put mine through 1'+ w/ no rear weight and it would still even climb hills.
   / How does a 4x6 Gator do at snow plowing? #7
Maybe light powder.
Here 1' of heavy wet stuff the gator will bulldoze 50-100' all the while pancaking underneath then spinout. No backing up either as the wheels are lifted off the ground.
Cousin plows his 500' and 1000' with a 4x4 ATV small, light, steers easy & fast. Only takes out the SS or tractor when the hwy apron berm is too much.
   / How does a 4x6 Gator do at snow plowing? #8
I plow with a 450 honda 4x4, no problems. So id IMAGINE that the gator would do good cause its naturally heavier and you could throw some sand or salt in the box to weigh it down... But others have said that it wont work.. so i dont know.
People do plow with the toolcats, but there a different beast.
   / How does a 4x6 Gator do at snow plowing? #9
I've got pretty much the same Gator -- a couple years older, gas engine. I have to agree with the "not so great for plowing snow" crowd. I struggled with it for years and finally got in the habit of using it only if there was 3 inches of snow or less. Even then, it was really easy to get stuck (always at the far end of the driveway, half a mile from the house).
Eventually I gave up and use the Power-Trac instead -- if anybody wants a good deal on my Gator blade, let me know. It hasn't been on the machine in 5 years.
It's a fantastic gizmo, we use it all the time. But not for snow plowing. :)
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2010 Chevrolet Express Shuttle Bus (A55852)
2010 Chevrolet...
2023 Toyota Rav4 AWD SUV (A55853)
2023 Toyota Rav4...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A57024)
2023 Top Air ATV...
2016 Chevrolet Traverse SUV (A55853)
2016 Chevrolet...
CATERPILLAR D6 CRAWLER DOZER (A52707)
CATERPILLAR D6...
