Hedge trimming the quick way.
   / Hedge trimming the quick way. #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Neat rig, probably can do ditches , and trees
   / Hedge trimming the quick way. #2
That is what my town highway department (mounted on a JD cab tractor) uses to mow/clear the roadside brush. I think it is basically a flail mower on a hydraulic arm. They also have a rear PTO driven one on the same beast to clear the area directly under the tractor. It is pretty cool watching them work with it. I am sure it is big $$$.
   / Hedge trimming the quick way. #3
ya they use the same setups here in ohio but they also have a rear mower on them also and yes they do ditchs, hillsides, freeways, and will mow your yard when you dont mow it yourself and charge you a arm and a leg. but also it is a awesome way to do your hedge trimming if you have the money. nice pic JJ
   / Hedge trimming the quick way. #4
I'd like to rig up a walk behind push mower on a mechanical telescoping boom mounted on the 3 point hitch.
Anybody ever done that and if so how did it work?
   / Hedge trimming the quick way. #9
Poor arrangement, as it requires the operator to be looking back while working. Pretty much the same concept though.
The link I provided was in response to LBrowns question (on whether a 3-point version was available for compact tractors) Of course, a 3-point mounted model would be to the rear of the operator. Quite frankly, I see NO difference in concept between the one in my link and the mower in your original post.
The same manufacturer, as well as several others makes simular units that "mid-mount" on conventional full sized tractors. In any event, you wouldn't need to "look back" so much as looking to the side with either design.
I've demo-ed a side mount boom mower on a couple of occasions. Once you're up and running, an occasional glance at the mower is all that is needed for the most part, much like when using a rear mounted bush hog. The side mounted boom mower I demoed had mirrors in place to watch the mower if the operator felt so inclined.
Bottom line, they beat the heck outta using a pair of hedge clippers! ;)
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
1982 MACK RD685S HOTOILER (A50854)
1982 MACK RD685S...
JOHN DEERE 544G (A50854)
JOHN DEERE 544G...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
