Tires Ford 1700, tractor front tire question
   / Ford 1700, tractor front tire question #1
James48843
My front tires are at the point they need replaced.
I am unable to read the tire size on the side of the tire. It is NOT the ag tires (5.50-16), but rather more of a turf type tire.
Anybody know what type of tire will work best for this? What size interchanges with this for front tires.
Thanks in advance.
UPDATE_ I was able to read the sidewall better now- they are Goodyear 20 X 8.00 X 10 , 2 ply. They are cracked so bad I can hardly read the writing, but that is what it is. Any ideas for compatible tires for this?
   / Ford 1700, tractor front tire question #2
Thanks in advance.
james,
My front turf tires are 20x8-10" dia as well. I think your tractor is 2 WD as mine is. I have not checked for a compatible size but I thought I found the actual size from Titan tires. I don't reckon it makes much difference in the dia if you don't have FWA. I just make sure both sides are the same.
JC,
Yes, 2WD.
thanks for the lead on Titan Tire- I found this one, which appears to be the only comparable:
Titan® Tire catalog
There is a dealer about 15 miles from me, and I will call them tomorrow and see about ordering a set.
thanks
   / Ford 1700, tractor front tire question #4
Yes, 2WD.
Titanョ Tire catalog
thanks
Should fit it like a glove as it is the OEM spec. If you would not mind could you get back with the pricing info. On one tire I have an occasional slow leak. might need to change mine in near future.
JC,
JC,
Local dealer talked to me- here is what I got:
20 X 8.00-10 tires.
I can get Titan brand, but it will take about two weeks to arrive. They can do a 4 ply 20X8.00-10 , price of $64 each, plus taxes. They also can do an 8 ply, for $66.50 plus tax.
The dealer also suggested, as an alternative, Carlise Turf Master, at $ 43 each, and Carlise Turf Saver, at $40 each. They can be ordered to arrive in two days. Those are both 4ply tires.
I am thinking that I may go with the Titan 8 ply, just because it appears to be a superior tire. Yes, it's $20 more than the Carlises, but it may be worth it in the long run.
My current Goodyears lasted 30 years- I would like a long-lasting replacement- although I kind of doubt I, or the Ford 1700, will be around long enough to have it matter....:)
   / Ford 1700, tractor front tire question #6
Great,
I second that, $20 in the long haul ain't nottin. I have Titan for my rear tires as the previous owner replaced them 8 years ago, and they sure look in perfect condition given my limited use.
JC,
   / Ford 1700, tractor front tire question #7
Definitely go 8 ply; especially if you have a FEL. Jay
   / Ford 1700, tractor front tire question #8
Goodyear sold their Ag & turf tire business to Titan. If you wanted Goodyear, it would've been a premium price.
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
2022 Behnke Trailer (A55973)
2022 Behnke...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
2001 FREIGHTLINER FL70 (A58214)
2001 FREIGHTLINER...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
