I've read dozens of threads here and I know this comes up alot. Hope you don't retreading old waters.
I have a JD955 sub-compact with rear turf tires, 36x13.50x15. I bought it used with FEL and snowblower, and occasionally use a brush cutter for maintaining woods trails mostly. The FEL doesn't get much use, lately just for little gravel filling jobs on driveway not amounting to much and to balance brush cutter weight.
When I bought the tractor used, it had calcium chloride filled innertubes in these big turf tires. It's been working fine until the inner tube failed on one of these rear tires around the valve stem. The tire, which is in good shape, is out for for repair and the shop is having a hard time finding a replacement tube. I plan to refill the one tire with Rim Guard, leaving the other as is with chloride until it fails or preemptively repairing it the same way as the tire now being worked on.
My questions,
1. Should I make due with an innertube that is close to size for filling? Nearest might be a 13.6/16. (Does that sound right?)
2. Should I instead go tubeless and fill with Rim Guard?
3. Alternatively should I forego the filling and just reduce my FEL use to lower loads, less height?
My main concerns are snowblowing on relatively flat areas and occasional runs through the woods for brush cutting with possible associated tire damage by rocks and sticks through sidewall. The tractor gets light use, and I'm more concerned about the hassle factor of dealing with repairs or maintenance issues and its vulnerability to such damage. It's stored in a garage mostly. I live in the far northern Midwest in the sticks.
It seems that the pros and cons of tube vs. tubeless have been well discussed here. Any other insights given my use? Thanks in advance for any input.
My questions,
