N80
Super Member
When I was thinking this out I knew I didn't want to spend much money, I don't weld and didn't want to pay for welding, but wanted something strong and easy to install myself. This is what I cam up with:
I got the d-rings at TSC:
Ring Anchor and Base, 11000 lbs - 3016822 | Tractor Supply Company
I use it with a pair of these:
2 in x 15 ft Size; 8500 lbs Capacity; With Hook. - 3040033 | Tractor Supply Company
The hooks where easy to install. I used grade 8 bolts with large washers on the inside of the bucket. The rings are large enough so that a chain can pass through it with its hook which allows for almost infinite adjustment. All it took was a drill and a couple of wrenches. I've used them many times to move implements.
It has been pointed out that the specs on these hooks read 11,000 pounds and the straps 8,500 pounds. I think these are the failure specs not what they are rated or recommended for. However, since my loader can only lift about 1500 pounds, I think they are well within spec for anything I'd do with them.
Just a thought. Super cheap. Super easy. Very versatile and lets you use chains, ropes or straps.
