centrifugal clutch and transaxle
/ centrifugal clutch and transaxle #1
whateg0
Has anybody ever used a centrifugal clutch with a transmission or transaxle? It seems like it would work, and would give you almost hydrostat-like functionality. But if it works, it seems like it would be more common.
My thoughts for a project involve a riding mower, which usually uses a spring-loaded idler as a "clutch" that goes to a transaxle. However, I don't necessarily have a good way of acuating the idler in my design. So, I thought about using a centrifugal clutch, but then I'm limited in my top speed. So, if I used a centrifugal clutch, I could just idle the motor down and it would be effectively disengaged.
Thoughts?
Dave
/ centrifugal clutch and transaxle #2
Short answers, "No", and "No" !! That said, since I'm reading that your 'designing', (Building from scratch'?), perhaps a variable v-belt type clutch would fit into your plans. Similar to those used in (old?) snowmobiles. The belt rides deep in the drive pulley and high in the driven pulley at idle, then as engine rpm gains, the pulley flanges compress on the engine end and expand at the driven end! Problem I see with a straight centrifugal clutch is that once it engages, the only speed adjustment is what throttle you've got left! A snowmobile bone yard would be a source, 'cause new, they'd be huge bucks! ~Scotty
/ centrifugal clutch and transaxle #3
Golf cart.
/ centrifugal clutch and transaxle #4
ZZ- Is that what they have?
/ centrifugal clutch and transaxle #5
That seems to be the way my Yamaha gas cart is set up. Once it get up to operating rpm, the centrifugal clutch deals out the speed to balance the load (hill climbing, extra payload, pulling a trailer, etc.) at a constant rpm I use mine for all around transport of "stuff" on the ranch: hay feed, firewood, fueling tanker, pulling the chipper and dump cart and portable rifle rack. Its a great way to run the dogs out in the field, too. Putting more motor on it would give you a nice CV platform to run a self propelled mower or ground drive implement. Cooling seems to be my only concern about my current setup. They recommend synthetic motor oil if you are gonna run at full power a lot. Maybe a remote engine cooling fan with a thermal sensor on it from a FWD car would improve this issue... There is a parts book for these carts on the Yamaha web site, Just pick a year and a gas type cart. You can see what the powerplant configuration looks like.
/ centrifugal clutch and transaxle #6
Thanks for the education! A neighbor (country-place) of mine has about 4, both gas & electric, to run around all his mowed trails on some 200ac. The Grand-Kids, think he's the greatest!!!! ~S
/ centrifugal clutch and transaxle #7
The Citroen 2CV car (aka ugly duckling) of the 50's, produced well into the 80's, had an optional centrifugal clutch in front of a 3 speed manual. The idea was to be cheaper than a fully automatic. I think the car had a 25 horse 3 cylinder W engine (a flat two with a third upright cylinder) which wouldnt be able to carry the weight of an automatic, and the cost would blow the price up way higher than anyone would give for such a pile of junk.\
Anyways, they advised the 1st gear for hill climbing, 2nd as city speed and 3rd as main road speed (it wouldnt get to highway speeds anyways)
I think they only sold it for a couple of years in the 60's because granny drivers (the main buyer target) would only use the 2nd and overrev it, or only use the 3rd and burn the centrifugal clutch when going uphill.
The Daf car of the 50's (with the Daf Variomatic belt transmission) had only 600cc but was quicker than many 6 cylinder cars of that era, because it was light, effective and the engine kept running at its optimum (the transmission acted not just on input RPM but also on intake vacuum: the car would lower the transmission ratio when you reached cruise speed and decreased engine power by taking your foot partly off the gas pedal, reducing intake manifold vacuum)
That worked great because the centrifugal clutch only had to engage at takeoff, with a low gear ratio, the centrifugal clutch would be fully engaged before the variator would increase its ratio.
/ centrifugal clutch and transaxle #8
Chushman used a centrifugal clutch in front of a two speed trans. it had a clutch pedel that would disingauge clutch to change gears. The Standred 4 wheelers have some sort centrifugal set up.
/ centrifugal clutch and transaxle #9
the variable speed double Vee pulley works reasonable to very well, (depending on the application) as it gears down the low speed and then converts to a higher ratio as it speeds up, (almost an automatic transmission in it self),
a centrifugal clutch does not let the motor have enough speed to get going in my opinion, when I was a kid I built a motor bike and it was not that good, if it would had the variable speed pulley like the units I was trying to copy it would have been great,
you will get in situations that you can not rev up the motor enough to get the clutch to engage solidly as there is to much drag on the motor, but not enough speed,
/ centrifugal clutch and transaxle #10
Polaris 4 wheelers use a CV Belt drive. Might find one cheap on ebay or craigslist
/ centrifugal clutch and transaxle #11
I was given a home made go kart and dropped an 8 horse into it. Didn't have a jack shaft to slow it down and smoked the brand new clutch right off the bat. You might be okay in first or maybe second,but you may have a problem in a higher gear.
/ centrifugal clutch and transaxle #12
JI Case had a "CASE-O-MATIC" transmition in the 60's and 70's , it was simalar to a centrifugal clutch or like the old plymouth fluid drive they were ok after you learned how to drive them.
/ centrifugal clutch and transaxle #14
Those Case used a torque converter, just as Fendt used in the 600 turbomatic E series of 1978 to 1992, and is used in wheel loaders, automatic car transmissions, etcetera.
Main problem with those is that they need slip in order to generate torque. That means they will produce heat and loose efficiency.
To back a trailer up a silage heap they are worthless, they loose speed before the engine torque has a chance to come in.
Fendt used a lockup clutch, electrohydraulically actuated (turbomatic "E") which helped save fuel, but often people overfilled the converter to decrease its slip percentage to make it lug on. IHC sold the same ZF transmissions in the German built 1255 and 1455, but they offered the torque converter optional only for 2 or 3 years, but it was taken off the option list because with the slip of a converter inbetween, you would only waste the torque of those DT 358 and DT402 engines ;)
/ centrifugal clutch and transaxle #15
MWB mentioned the Comet converters already and you can pick them up on ebay.
MTD built several different brands, ( I have a 1980's Wizard) that used the torque converter set up and is still going strong. You can spot them because they have 7 speed a shift lever on the right fender that is actualy a control lever for an infinitely variable torque drive like the snowmobile torque converters already mentioned. The "clutch" on the left side just moves one of the drive pulleys sideways exactly the same as the shift lever and allows you to slow down or speed up without shifting. If you can find one, You'll have the whole shebang. You might also cosider the older Snapper friction drive units. They have a steel disc about 5-6" dia., running off the engine crankshaft to the rear, where a wheel with some kind of rubber tire on it, slides across the disc face and chain drives the rear axle, forward on one side of the disc, reverse on the other, with neutral in the center. This eliminates the clutch and transmission altogether.
Smiley
/ centrifugal clutch and transaxle #16
I always heard these things called "Salisbury Clutches", and purchased a new one back in the '70's to power a "Dune Kat" that I pulled the 5hp motor off of, and put a new 8hp on in it's place. Durn jackshaft cost me $50 to have keyed at a local machine shop. (way too much back then!). I later graduated to a Honda Odyssey (not the mini-van) when they came out with them in the late '70's. Had a lot of good times with that sand buggy, but since they were belt driven via a varible pitch pulley, they did not like water AT ALL! I would prefer one to a centrifugal clutch any day, as it gives you a long range. I think the Odyssey was a drive ratio of 2.73 to 1.00 and overdriven to 1.00 to 2.73 which was quite a range. I may be wrong on those exact numbers because it has been years since I drove one, and we modified both the engines and the drivetrains on them to make them run FASTER. From the factory they would run about 45mph, but I got radar'd on the local sandunes in excess of 83mph.
Brings back memories of good times,
David from jax
/ centrifugal clutch and transaxle #17
Those cheap friction puck Comet CVTs work pretty good with a Briggs 8hp and the like.
That what we used back when I competed in SAE's MiniBaja. not exactly high performance, but that isn't what you are looking for.
just remember, those belts don't last forever.
/ centrifugal clutch and transaxle #18
I think it will work fine and it will not limit your top speed, just your bottom speed. With the conventional belt engagement, once engaged you can power along real slow in 1st gear with the engine idling, with a centrifical clutch you will need to get the engine up to around 1800 rpm to engage the clutch and you will loose any engine braking on the down hill so make sure you still have the brake working. IE when my brake failed I could stop the tractor by cutting the ignition, can't with a centrifugal clutch.
Ford Tailgate Themed Wall Decoration (A61569)
Ford Tailgate...
New/Unused 72in No Till Seed Drill (A61166)
New/Unused 72in No...
2016 Ram 1500 Crew Cab Pickup Truck (A61568)
2016 Ram 1500 Crew...
ALUMINUM HEADACHE RACK (A60736)
ALUMINUM HEADACHE...
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
New/Unused Landhonor Quick Attach Hydraulic Pallet Forks (A61166)
New/Unused...
