Rotary Cutter HP required for a 15' Bush Hog?
   / HP required for a 15' Bush Hog?
One GOOD thing with a batwing....Their width can allow you to make 180 degree turns where you can double back on your previous pass. (provided you get a mower w/ correct pto shaft)
Oh, now that sounds nice! :) But how do you know if you are getting the correct pto shaft to allow sharp turns like that?
Thanks to all for your informed comments. I'm trying to digest it all :)
Ken
   / HP required for a 15' Bush Hog? #12
Ken
Some have regular u-joints in the pto shaft and some will have (optional in many cases) CV joints. Talk with the dealer in your area.
   / HP required for a 15' Bush Hog? #13
Farmwithjunk,
I've been eyeballing the Tiger setup; went so far as to email them with several questions. They claim it can work with a FEL attached. However, you state it takes a dedicated tractor. Can you not detach either rear flail? Does the side flail not allow the use of the FEL?
(sorry slightly OT) I would be purchasing this in a couple of years after I put in irrigation and about 30 acres of a 45 acre plot planted in chinese chestnuts. Also, I plan on buying more acerage for additional chestuts or improved black walnut or northern pecans. Plan is to buy a cabbed tractor in the 85 pto hp range and pay my dad to mow as I'm in the Army. These trees should come productive about the time I retire from the military. Trees would be on 30' centers for the first 15-20 years with a 6-8 ft strip of landscaping cloth/pine needle mulch. I am thinking the tiger setup would be great for this. However, because of the $, I might just go with an 8-12ft brush hog orchard flail and sneak it down the backroads if I have to jump from farm to farm (plan is to buy a couple more farms in the 100 acres range for a total of 250-300 acres and within 3-5 miles of existing property). This is in rural North Central Missouri. Slightly rolling to flat marginal row crop ground (my 45 acres is currently being row cropped but would have made an ideal candidate for CRP--averages between 30-35 bushels of beans). Pasture floor will be either white clover/bluegrass mix or red clover/timothy mix.
Thanks for any input.
   / HP required for a 15' Bush Hog? #14
Farmwithjunk,
From what I've seen, you CAN use the tractor for other chores, but the side mounted flail would be very time consuming to remove, or else it would be in the way if working in tight quarters. Since I'd be buying one for mowing purposes only, I'd only remove either the rear OR the side mounted mowers if and when it was a matter of servicing the tractor.
I know laws vary widely from state to state, but you don't have to "sneak" farm equipment around here in Ohio. All you need is an SMV sign and you can take just about anything down any road other than a limited access highway. We regularly see farm equipment blocking traffic on US 68, some of it probably 15' wide.
Ken
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
Wooden Rocking Chair (A55853)
Wooden Rocking...
2018 International Durastar 4300 Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A55852)
2018 International...
2016 Ford Expedition SUV (A55853)
2016 Ford...
Caterpillar D3C LGP Crawler Tractor Dozer (A55851)
Caterpillar D3C...
2014 Volkswagen Passat TDI SE Sedan (A55853)
2014 Volkswagen...
