Draft and position control???
/ Draft and position control??? #1
dennis5150
Member
Can somone explain what draft control is and what position control is, and how they are used?
/ Draft and position control??? #2
Position Control is just your up down movement of the 3 pt lift mechanism. that having direct impact on the up/down position of the implement. Example setting the Position Control so that it is all the way down, or say an inch of the ground or all the way up. Draft Control is a sensitivity setting. the device senses the amount of resistance on the implement, maybe a rear blade and at least mine will raise the implement if the blade encounters to much resistance as in when it grabs and really starts to dig maybe to deep or encounters a root, rock, etc.
/ Draft and position control??? #3
Also be aware that some of the Kubota's have an extra special 1/4 inching control. It doesn't seem to work on my tractor, but a lot of Kubota owners complain about it.
/ Draft and position control??? #4
So, if you don't have draft control, what happens when your blade (or whatever you have attached back there) encounters a rock/root/boulder it can't move? Bent blade? Stalled tractor? Damaged hitch? Spinning wheels? Or will it pop up and mess up your hydraulics? Or...?
What is that?
Newbie, wanna be a knowbie :D
/ Draft and position control??? #5
What is that?
As the name implies, the lift arms move in 1/4" increments rather than smooth and infinitly adjustable strokes. If say you were tring to hook up a plow, and needed the arms up (or down) a fraction of an inch, the inching system may jerk past the perfect position.
/ Draft and position control??? #6
What is that?
All of what you said could happen except mess up your hydraulics. The weakest link principle applies. There is no other clear universal answer as it depends; on the tractor and is power to weight ratio, the implement and its ability to stop the tractor, the inherent strength of the implement, etc, etc.
That clears up the mystery (at least for me) thanks for the explanation.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
HEIN-WERNER 1TON TRANSMISSION JACK (A63569)
HEIN-WERNER 1TON...
