How many hrs?
/ How many hrs? #1
tinman955
Gold Member
Pennsylvania
2011 Bobcat CT450 Cab Hoe
So since we have alot of new bobcat owners how many hrs do you all have?
I have 25 hrs and it does seem to be running better but still seems underpowered, I hope after a 100 hrs or so it will run better.
/ How many hrs? #3
Im at 21 and running just fine, dont know if its underpowered or not I made a big jump up to the 225
/ How many hrs? #5
I think I am just over 20.I am very impressd on fuel consumption. I got 10 hours out of a tank.Getting more used to it each day. It has alredy made me a litttle money. I have had a flat already but that comes with the territory when you are working on another man's land.
/ How many hrs?
Sounds good so far im glad to see everyone is happy!!:D
/ How many hrs? #7
I think I'm about 16 hrs. So far so good. I just need to get some more implements so I can run up the hours!!!
/ How many hrs? #9
25hp ct225 36hrs I am using more diesel than I'm used to. Ive gone thru 25 gal so far, tractor had 10! hours on it delivered so I'm using about 1 gal/hr. Mostly running the rear pto to mow.
/ How many hrs? #10
That's over twice what I am using and I have been doing the same thing. I have used way less than 2 tanks(5.8 gal each) and I am close to 25 hours. You may need to get your machine checked out
/ How many hrs? #11
Ive got 22 hours as of last nights mowing and Ive filled the tank once. sounds like yours is either running rich or you are running it flat out all the time. what rpm are you mowing at?
/ How many hrs? #12
28 hrs now on CT225 and I use almost a gallon an hour while mowing in low range on hills with a RZ160 Bush Hog! Tractor is running great and seems to have plety of power. I will install my factory dual rear remote kit today.
/ How many hrs? #13
I have 27 on my 235 and burned about 15 gals. so far. Mostly front end work cleaning up old torn down house debri and about 8 hours bushhog work. So far tractor seems to have plenty of power I hardly ever run it above 1800 rpm except to spin the PTO for bush hog work and that feels like too much.
/ How many hrs?
Ive been doin a lot of hoe work as of late, I really need to get a PSI reading on my hydraulics. I suspect im down on PSI because of my lack of hydro power for loader and hoe. I dug up a stump and was trying to pick it up out of the hole and couldnt do it with the hoe or loader. I finally had to do it with my other diesel, 07 Duramax btw I didnt run out of power with it!!!:D Ha Ha
/ How many hrs? #15
nice to have a back up plan, mine is an 05 dodge cummins. not as much loader power but sure can drag more than my 225
/ How many hrs? #19
Tinman, Check your inbox...I sent you a PM with a few ideas on power loss.
Sprocket,
I would really like to hear your thoughts/ideas too on power loss issue as I am waiting on my CT230 still thanks
/ How many hrs? #20
Sabertooth, Sorry work has me jumping right now. I have noticed that multiple hydraulic functions effect the power on my tractor. This is to be expected from a heavy somewhat low HP compact tractor. I was using my FEL to pull some posts that were cemented into the ground and was not real impressed with it. I noticed that sitting still my tractor will creep forward if the parking brake was not engaged. I put the hydrostat in neutral and seemed to get more out of the FEL. I adjusted the shuttle shift properly to resolve. My thinking is for you guys with power issues to look for any system controls that could be reducing the flow to the desired function of use, rear remote detent, shuttle adjustment ect. you can also buy a gauge and a QD male fitting and plug into the Loader or rear remote connection and watch the pressure at that point and the effects of the other functions on it. If a few of us do this we can establish some baseline data to evaluate our issues.
I have also used the Kioti forum for lots of info. I am happy with the power of my tractor but it does take some control coordination to make the most of it.
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2015 Kawasaki Mule 4x4 Utility Cart (A61572)
2015 Kawasaki Mule...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
John Deere 4040 Tractor (A64047)
John Deere 4040...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
