Mowing 12' finish mower
/ 12' finish mower #1
herrick
Central, IL
What's the smallest tractor you can use to run a 12' batwing finish mower?
I currently run a lawn service and am looking at getting into larger properties (schools, parks, etc). I currently have one 40+ acre retirement community (about 20 acres of grass) that I maintain, and enjoy it enough that I'd like to concentrate more on this type of work. I'm also looking at adding fert. and weed control services next year (after I get my license). looking for the smallest tractor that will acceptably run something like a 10-12' pull behind batwing FINISH mower. (not a bush hog) I want to stay as small as possible to minimize weight for compaction on the grass, and for ease of transportation. Most say you need at least 30hp to run them, and it looks like a JD 3520 is right at the 30 PTO hp required... anyone with real-life experience think this will be a decent combo? or do I really need to go bigger?
/ 12' finish mower #2
The first batwing finish mower I saw was used with a 3720. What are the pto requirements of the mower you are looking at? JC
/ 12' finish mower #5
Herrick:
I tried a 15' Batwing mower for a week on my 3720. :) The dealer had a used one come in and dropped it off for me to try. There is a post on here with pictures: http://www.tractorbynet.com/forums/john-deere-owning-operating/103614-my-3720-15-wing-mower.html
With 35pto HP I didn't suffer for HP much and (you'll have to read the post) but probably mowed at 5mph. I have a single short steep (maybe a 10' rise) hill but that's it so I can't give a review of running it on hills. I also was mowing I think 2 weeks growth.
It weighed 3200lbs which was over 1/2 the fighting weight of my 3720 cab (about 6K [loader frame, loaded tires, etc.]). I would imagine that it could wrestle the tractor around a bit on hills but in my short use I didn't have any issues.
It had a drawbar hitch rather than a 3pt which I thought made it handle better. Technically the drawbar weight for transport (wings up and off the ground) exceeded the max recommended for the 3720 but the operating tongue weight was fine.
/ 12' finish mower #6
I also do a lot of custom landscape work design/build and find the 4x20 is better all around. While the 4x20 series is heavier it has larger tires so with equal tire pressures the compaction is the same on the lawns. If you notice there are lots of 5000 series tractors in use for golf courses as an example. I would hesitate buying too small a tractor only to find out you need one larger next year for some other type of work.
Steve
/ 12' finish mower #7
I use to use a JD 1050 which had 33 pto hp with a 12' woods finish mower with no problems. I had fairly level lawn and the tractor was MFWD if I got in a soft spot. I moved up to a 17' Woods finish mower and pulled that behind my 990 which had 35.5 pto hp. That would make the 990 work if the grass got ahead of me, so this year I upgraded tractors to a 4520 and this tractor pulls the mower like its not there. I would now recomend a 4x20 series so you do not lack hp or give up longevity as it is your business. This is just my opinion though.
/ 12' finish mower
Well, not a ton of hills that I have to deal with around here as far as mowing. Worst would be a ditch here or there, which the ZTR would probably be better on anyways with it's low center of gravity.
The other reason I was concerned with weight was for transportation reasons. My truck is good for about 9k towing, and with a 3k tractor (3X20), maybe some weights or loaded tires, and a 2-2.5k mower (plus the trailer) I'm going to be right at my limit. Seems like a 3720 with 35 PTO hp may be a decent match with a 11-12' mower. This would all be weekly (if not sooner) cutting, so I shouldn't be asking too much out of it.
/ 12' finish mower #9
Not to be overbearing but with a 4520 weighing in about 3700#'s OS and 4500#'s cab this isn't much more than a weighted 3x20 series. This is a lot more tractor to build the business around, I wouldn't base the tractor purchase around a trailer's capacity. Mowing 20 acres every week is a time consuming task but would be alot more pleasant to do with a 4520 or 4720 cab tractor with an economy pto. There are a lot of people here who can vouch for the fact that trading up constantly is much more expensive than buying the right tractor the first time. I pull my 110 tlb and 4520 on a 12,000 lb trailer with a Ford 550 service truck and yeah it took me a while to get it together but buying once made it that much easier.
So if I were in your shoes I would buy an unweighted 4520 and add weights later when needed, much cheaper than upgrading the tractor.
Good luck with the tough decisions.
Steve
/ 12' finish mower #10
quote]
I use a ztr on some hills but my 2320 and 4120 handle the slopes and ditches much better. Not sure what ztr you are running but it has been my experience that you may like the tractor better for this application.
John
/ 12' finish mower #11
Sometimes it seems that the tractor is unstable, but it might be OK. I find out that it takes me a while to find the limits.
That is one serious finishing mower,
D.
/ 12' finish mower #12
Herrick:
6,000 lbs sure seems high for a 3720. I would have never figured that. I have a HX-15 batwing I pull with my 5525. I considered hooking it up to my 4720 but I think the batwing weighed more than the tractor. Also it needs 2 rear valves to run it properly.
D.
/ 12' finish mower #13
D.
Darin you can setup 3 hyd valves on the rear of the 4x20 series.
John
/ 12' finish mower #14
John
On my 4520 I removed the front steel lines and replaced them with 4' hoses run to the rear. I use these with the joystick for the top and tilt. The 3rd rear outlet is used for pull type wheel cylinders and boxblade toothbar. It is nice to have a tractor without a fel on it, really helps in tight quarters.
Steve
/ 12' finish mower
Herrick:
I noticed that you went with an 84" RFM in the end... do you get much if any scalping with that? How fast can you run with it and still get a nice cut?
/ 12' finish mower #16
D.
Base weight for Cab unit is just under 3600lbs. I have probably 800lbs in the tires = 4400lbs. The loader frame (no bucket) is 1100lbs for 5500#. Me and some other crap I have on it brings it even closer to 6000#.
The loader and loaded tires add almost 2Klbs. I had the large R4's and they took 900lbs of RIM Guard. I have R3's now and I figure they probably take 800lbs of fill. (Rim Guard is over 11lbs/gal).
When I was using that Batwing I had the large R4's and I think those ones were unloaded.
/ 12' finish mower #17
I get some scalping if I run over crowned areas but I don't have many of those fortunately and I just cut them differently (direction-wise). Also, when I cut with the 72" MMM I think it would scalp also.
The tip speed on the unit I got (Made by Woods) is like 16,900ft/min (more than the JD unit advertised the year I got mine, I think I got a later model that they sped up.)
I've cut as fast as 7-8mph (full speed in mid range) still getting a nice cut but bounce a lot. This season I put on a mulch kit that I got from woods on it so I mostly keep it under 6. My lot is mostly flat and level but there are a couple of washboard areas. The mulch kit works pretty well but if the grass is high I'll leave a little grass poop behind.
Where I do scalp terribly is when I (my fault) back up to the top of a hill too far and the rear wheels drop and let the blades go real low. :)
I wish they put cranks on the height adjusters instead of the shims but I've only ever seen that on an old 60" Swisher pull beside mower I had.
/ 12' finish mower #18
That is some weight - nice.
D.
/ 12' finish mower #19
Just curious, why would anyone want to load the tires on a mowing machine that they are concerned about ground compaction? (or is this a shootoff of the original post?) I would think the widest tire size available and zero added weight would be the best deal...
David from jax
/ 12' finish mower #20
Good point. I can see that with a 3000 lbs mower that loaded tires on a 3500 to 4500 lbs tractor would be an advantage.
MarkV
2017 TAKEUCHI TL12R2 SKID STEER (A64279)
2017 TAKEUCHI...
2012 Toro Z Master Professional 72in Zero Turn Mower (A61572)
2012 Toro Z Master...
2014 JEEP GRAND CHEROKEE (A64280)
2014 JEEP GRAND...
2021 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
2021 Land Pride...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
13' ORLANDO CLIPPER FIBERGLASS JOHN BOAT (A64281)
13' ORLANDO...
